So what you're saying is that your engine doesn't have enough displacement to spool the tiny turbo that you have?float_6969 wrote:Why won't it be making power? The whole point of this system is to increase the power when you launch the car so that it doesn't bog off the line.
No. Never said that. It spools this turbo way too fast. This turbo isn't staying on the car. I'm just using it for a turbo comparison, CA T25 vs. SR T25 vs. S15 SR T28. Once that comparison is done, the motor will have an HKS turbo kit that uses a T04E-50 Compressor in a .50 housing with an O-trim wheel in a .48 housing. Although that turbo should spool decently well, it won't have a whole lot of grunt off the line. So the launch control will allow me to easily make enough power to launch quickly and consistently with much less effort.PoorManQ45 wrote:So what you're saying is that your engine doesn't have enough displacement to spool the tiny turbo that you have?
I don't need it. I don't need a car either. I could walk everywhere. I have it because it's a built in function of my standalone, it's easy to hook up, and will help me launch more consistently at the drag strip and autoX's.PoorManQ45 wrote:Why do you need this setup?
An engine's exhaust flow IS relative to load. What you're saying is that at 3K rpm I'm moving the same volume of gas at 10% throttle and 100% throttle. If you think that's true, you need to do some research on how a traditional throttle plate, spark ignition, internal combustion engine works.PoorManQ45 wrote: I am not understanding your reference saying "at idle with no load". An engine's exhaust flow is not relative to load. It is relative to RPM x CC. So please explain that a little better.
They didn't question me. They were right. It's not an anti-lag, it's a launch control. I repeatedly agreed and admitted that I was wrong for posting it with that title. If I was being childish, I wouldn't have put (title corrected) in the corrected title.PoorManQ45 wrote:Oh, and it's childish to change posts because they question you.
Huh? On a typical system the TB is connected via a linkage to the accelerator pedal. The TB should be open 100% when the pedal is on the floor. Under load the timing can be advanced or retarded, depending on engine design. The amount of fuel is relative to the spark advance vs rpm.float_6969 wrote:An engine's exhaust flow IS relative to load. What you're saying is that at 3K rpm I'm moving the same volume of gas at 10% throttle and 100% throttle. If you think that's true, you need to do some research on how a traditional throttle plate, spark ignition, internal combustion engine works.
If this was a diesel, then it WOULD move the same volume of air at 3K rpms @ 10% throttle and 100% throttle.
If you're the one that edited my post, then yes.float_6969 wrote:And are you really in a position to come in here and accuse me of being childish? You're PMQ.
Yes the TB is connected via linkage and I have 100% throttle when the pedal is on the floor. Yes, I program what the timing is based on RPM and engine load (MAP sensor). Yes, the spark advance has an effect on the AFR and so the amount of fuel injected is dependent on that.PoorManQ45 wrote:Huh? On a typical system the TB is connected via a linkage to the accelerator pedal. The TB should be open 100% when the pedal is on the floor. Under load the timing can be advanced or retarded, depending on engine design. The amount of fuel is relative to the spark advance vs rpm.
No. Maybe if I describe the process in detail you'll understand what's going on. I'll give you 2 examples. 1st example: I'm pulling up to the tree at Heartland Park Raceway in Topeka KS (my local drag strip and road course). I stage up and depress the accelerator pedal. From experience, there is a very small window of RPMs that I have to maintain to launch properly. When that motor was in my old S13, it was about 3400-3450 RPM's. Maybe I just suck, but trying to maintain RPM's in a 50RPM window is hard to do. Not impossible, but hard to do. As the lights drap, if I don't have the RPM's in that range, the motor will bog if I'm below that range, and if I go over that range, I have to slip the clutch a lot to keep the wheels from spinning when I launch.2nd example:I'm pulling up to the tree again and stage. This time I have the launch control activated. I depress the clutch and put the accellerator pedal to the floor. (The following numbers are made up because it's winter here so I can't program it yet) I've programmed the system to limit RPM's to 3K RPM's and the timing is retarded 10° from standard, giving me a total timing of 18°BTDC. This amount of timing retard causes the combustion process to start late enough that the exhaust valves open just before the combustion process is finished. This small amount of extra energy is passed out of the combustion chamber, past the exhaust valves, through the exhaust mnifold, into the turbine housing, and past the turbine blades, causing them to spin faster than they would if the engine wasn't running any timing retard and was just limited to 2K RPMs. This allows the compressor to spin fast enough to create 10psi of manifold pressure. Without the timing retard the compressor will only create 2psi of manifold pressure. With this process started I can simply dump the clutch and have a perfect launch every time the lights drop.PoorManQ45 wrote:What you are doing is basically making each cylinder run so poorly that the engine can't physically spin any faster.
I can limit the TB opening in 1st gear via my right foot. It's not a very accurate or consistent system. The launch control system makes this whole process accurate and consistent. This makes launching the car much more predictable and repeatable.PoorManQ45 wrote:Again, I will ask, what is the advantage of this system over a properly sized turbo with a proper RPM limiting circuit? By proper, I mean limit the opening of TB prior to 1st gear engagement. You can program both spark advance and fuel increase/decrease.
I didn't know your post had been edited. IDK why anybody did that, it certainly wasn't me. I know I don't post in Gen-Chat much, but I'm not the type of Moderator that would edit someones post in my own thread.PoorManQ45 wrote:If you're the one that edited my post, then yes.
Now that makes sense. I thought you were going to run it like that on the strip.float_6969 wrote:In the video I purposely programmed the unit to run at about 3K RPM's and 35° of timing retard, giving me a total timing of 7°ATDC. This causes the combustion process to start SO late that the exhaust valves open a few moments after the spark has fired. This obviously causes A LOT of exhaust energy to be wasted out of the exhaust. This allows for A LOT of boost pressure to be created at a very low RPM. (Show me a turbo setup that creates 18psi @ 3K RPM on a CA18DET without this system and I'll show you a turbo setup that runs out of air way before the 7500RPM redline) I would never run the system setup like that on a normal basis. It was purely for entertainment purposes, but the system will still do that to some extent even when it's properly setup.
Now another question: The amount of gas that escapes the combustion chamber is going to cause a much higher pressure in the exhaust. How will this affect the reliability of the turbo?
Well this thread is turning pretty technical but what I am trying to say is this...float_6969 wrote:Why won't it be making power? The whole point of this system is to increase the power when you launch the car so that it doesn't bog off the line.
Man, what's with all the CA hate?
As for the two step making power...RCA wrote:Wait, that is a 1.8L...
You are going to let allot of people down...
The explosion occurs in the combustion chamber, it's just that the exhaust valve is opening while the expansion of that explosion is still occurring. An anti-lag system used on rally cars is more like an explosion in the exhaust, and those turbo's will last at least one rally race.PoorManQ45 wrote:How much are we talking here?
Basically you have an explosion in the exhaust. I figured that would blow something up pretty quickly
Where are you getting a 14 second 1/4 mile from? I'm not keeping that CA T25 on there. Did you see this post?RCA wrote: Well this thread is turning pretty technical but what I am trying to say is this...
You line up, and your two step goes off and makes all that noise (sounds and looks bad a*s)...Alot of people will be thinking, "Whoa, this thing is going to move" and then they get a 14sec qrt mile. They will be disappointed.
If I can't run any better than a 14sec 1/4 mile with that HKS turbo, I'm in need of some driving lessons.float_6969 wrote:...This turbo isn't staying on the car. I'm just using it for a turbo comparison, CA T25 vs. SR T25 vs. S15 SR T28. Once that comparison is done, the motor will have an HKS turbo kit that uses a T04E-50 Compressor in a .50 housing with an O-trim wheel in a .48 housing. Although that turbo should spool decently well, it won't have a whole lot of grunt off the line. So the launch control will allow me to easily make enough power to launch quickly and consistently with much less effort...
Because it is a CA and it won't be making enough power to make all that noise justifiable.float_6969 wrote:Where are you getting a 14 second 1/4 mile from? I'm not keeping that CA T25 on there. Did you see this post?
For how funny that sounds, it is more often than one thinks...PoorManQ45 wrote:Hey float, how does it feel to have motorcycles with bigger engines then you
Dude, please shut up when you don't know what are you talking about... You don't know a damn thing about CA18DETs. That HKS turbo could put that thing near 300HP, dingus.RCA wrote: Because it is a CA and it won't be making enough power to make all that noise justifiable.
It requires just about as much work to make either very powerful. The CA actually has more support than the RB20. You do understand they make about the same power with the same boost, right?Chaotic_Warlord wrote:however the RB is an RB and as such is an inline 6 w/ a turbo and is capable of making more power than the CA with less work.
OK, 4 things:The CA18DET was never available here in the states. I don't know where you are getting this "easier to make pass emissions" thing.Chaotic_Warlord wrote:I do understand that the CA is available in our junkyards as it was an option in the Z31 and the S12 making it easier to pass at your local DMV
LMAO. There isn't any response to that. It's just pure stupidity. Do some research on the CA. Check out forums based in the UK and Australia. The CA is a VERY popular motor in those countries and it's for a good reason. It's a well proven motor. It makes good power, is small, lightweight, and reliable. Anyone who says a CA can't make power is someone who knows nothing about the CA, it's as simple as that.RCA wrote: Because it is a CA and it won't be making enough power to make all that noise justifiable.
LOL, not the first time I've heard that, and one of my co-workers motorcycle DOES have a bigger motor than me, but the little CA still gets the job done.PoorManQ45 wrote:Ut oh, now the flaming occurs.
Flame on!
I chose the CA for weight and reliability. You can argue that it's not that much lighter than an SR, but I've seen an SR swapped S13 and CA swapped S13 side-by-side, and the CA OBVIOUSLY has WAY less weight on the front of the car than the SR does. I think the weight differences being spread around the net are inaccurate.Chaotic_Warlord wrote:Just out of curiosity... Why did you opt for CA18 instead of the RB20? Both engines are old, both engines run roughly the same price for the parts for the swap, neither engine are considered mainstream enou for the kid down the street to have one in h is car. however the RB is an RB and as such is an inline 6 w/ a turbo and is capable of making more power than the CA with less work. Not to mention an RB20 sounds way sexier than the CA does on the other end of the exhaust. Just my .02 cents and just askiing out of curiosity. Now I do understand that the CA is available in our junkyards as it was an option in the Z31 and the S12 making it easier to pass at your local DMV, while the RB never came here and as such is not in our DMV's databases, is this why you went with the CA or was there a deeper reason.
As far as weight, are you sure? Were talking iron block over alum. Dont get me wrong, between the two I'd choose a CA anyday, being a former owner of several myself. You cant beat an iron block with cam over bucket actuation aside from a cheaply made alum with rocker arms.float_6969 wrote:I chose the CA for weight and reliability. You can argue that it's not that much lighter than an SR, but I've seen an SR swapped S13 and CA swapped S13 side-by-side, and the CA OBVIOUSLY has WAY less weight on the front of the car than the SR does. I think the weight differences being spread around the net are inaccurate.
Yea sure unless your taking this thing to 450+ hp, the noise will let people down. Also the amount of money involved to get this thing to 300+ is laughable.float_6969 wrote:LMAO. There isn't any response to that. It's just pure stupidity. Do some research on the CA. Check out forums based in the UK and Australia. The CA is a VERY popular motor in those countries and it's for a good reason. It's a well proven motor. It makes good power, is small, lightweight, and reliable. Anyone who says a CA can't make power is someone who knows nothing about the CA, it's as simple as that....
we should all be swapping 10L V12's into our cars.
As far as the weight difference between the ca and sr, I wouldn't think that it is more than 50 pounds. Also, isn't the ca shorter than the sr? If it is that would explain the difference in ride height between a ca and sr swapped s13 with the stock suspension. (or one car just had blown shocks and sagging springs)float_6969 wrote:
Everyone knows the de and det sr's have inferior valve trains, when compared to almost every other Nissan power plant, thats why I want to ditch my det head in favor of a sr20ve and/or vet head.(I'll take which ever I can get my grubby little hands on)floatingPoint wrote:As far as weight, are you sure? Were talking iron block over alum. Dont get me wrong, between the two I'd choose a CA anyday, being a former owner of several myself. You cant beat an iron block with cam over bucket actuation aside from a cheaply made alum with rocker arms.
No. I'm not sure. I won't be until I see them both on a scale side-by-side. But what I do know is this. I picked up my CA block with the main caps, girdle, and main bolts in it with one arm, and the crank with another, and carried it into the machine shop. I tried to do that with my friends SR, right after I picked up the CA block, and there was a NOTICEABLE weight difference. I could pick up the SR block and carry it, but it hurt like hell. The CA block was heavy, but picking it up certainly was not strenuous. The same goes for the head. I thought for the sure CA head would weigh more than the SR head due to all of the extra weight from the bucket lifters, but to me, the SR head was heavier, and my friend who owned the SR motor thought the same thing about the block and head that I did.flohtingPoint wrote:As far as weight, are you sure? Were talking iron block over alum....
LMAO, YOU'RE laughable. You OBVIOUSLY know nothing about the CA. 300+ HP on a CA18DET is as simple as this;Fuel pump444cc injectorsZ32 MAFSFMICT28IntakeBoost controllerChip tuneI'm pretty sure, that's the EXACT same mods you need for 300+HP on an SR as well.RCA wrote: . Also the amount of money involved to get this thing to 300+ is laughable.
Agreed.RCA wrote:And yes tons of people swap LSs, JZs and other motors that have more then 1.8L. Also people would be willing to stuff a 10L V12 if it fit...
And you don't think there is anything wrong with that?float_6969 wrote:LMAO, YOU'RE laughable. You OBVIOUSLY know nothing about the CA. 300+ HP on a CA18DET is as simple as this;Fuel pump444cc injectorsZ32 MAFSFMICT28IntakeBoost controllerChip tuneI'm pretty sure, that's the EXACT same mods you need for 300+HP on an SR as well.
I am sure it can but I was laughing because you made 300hp sound like it should impress some one. It isn't much and so I laughed.Dattebayo wrote:With supporting fuel, sure it could; only about 500cc injectors. Hell, it could be done with an S14 turbo.
I don't see what's so funny. You really don't know what you are talking about!Here's a link, doofus: zer...eeded
FlatBlackIan wrote:[Japanese accent]OOOooooh Misfiring system[/Japanese accent]
FTMFW.
No. Why should I?RCA wrote: And you don't think there is anything wrong with that?
300HP would impress A LOT of ppl in an S-Chassis car. Is it a crazy amount of HP? No, of course not. Would it impress me? No, I've owned, driven, and built multiple, 300HP S-Chassis cars. Has way more HP been done with the SR, KA, and CA on multiple occasions? Yes. "It isn't much" is a relative phrase. We could argue about whether 300HP is a lot of HP till we're blue in the face and still get no where.RCA wrote:I am sure it can but I was laughing because you made 300hp sound like it should impress some one. It isn't much and so I laughed.
Big talk for a guy sportin' a stock KA.RCA wrote:you made 300hp sound like it should impress some one. It isn't much and so I laughed.
