JohnPa »
https://forums.nicoclub.com/johnpa-u27160.html
Mon Jan 16, 2006 9:10 pm
My 90 Q45t has new motor mounts, transmission mount, and a new factory driveshaft. It still vibrates at around 60mph. I also have new tires with a 'dynamic balancing' job, new differential mounts, a new left rear wheel bearing, and a used replacement right half shaft.
My next step is to put the car up on railroad ties (for safety) and run it up to speed to try and find the culprit. I won't get to it for a couple of weeks, so if anyone has some other ideas to check out, I'm all ears. I actually suspect the transmission although I admit I haven't done the brakes yet.
John in Seattle
