Jeff Taylor wrote:The tach signal for the dyno was a little screwed up, so my displayed engine rpm and torque curve aren't accurate. However the measured power is.
It looks to me like it's really making about 430lb-ft at peak.gammer_ghn wrote:Holy crap 635 TQ wooooooow with my stocker 4.1 i cant realky get passed the stopsign without churping at 2k rpm i guess your doing standstill all day errday haha nice one!!!
The car currently has stock 195mm rear tires on it...lol Anything after 4500rpm in 1st, 2nd, 3rd, and sometimes 4th puts the car sideways.gammer_ghn wrote:Holy crap 635 TQ wooooooow with my stocker 4.1 i cant realky get passed the stopsign without churping at 2k rpm i guess your doing standstill all day errday haha nice one!!!
I'll post a Consult datalog of the pulls soon.Carl H wrote:very nice numbers...when did the injectors max, do you have an exact rpm/airflow?
Video: http://filebox.vt.edu/users/je...i.wmvelwesso wrote:WE NEED A VIDEO!!!
Yeah. I'd say it was at 6psi by 4500rpm.sijoko wrote:Very nice! Are you still running the 1.08 housing on the TV7512? At what rpm does the boost show up?
Yeah, I didn't expect to max out the injectors until around 10psi, but this engine/turbo combination seems to be more efficient than I thought. I suppose I could increase the fuel pressure or lean out the top-end slightly, but for now it seems very reliable on 93 octane.qsiguy wrote:In light of these numbers I think I will need to set stage 2 at 6 psi instead of 8 until I'm ready to make the jump to larger injectors and MAF.
That has to be exciting for you getting on the road. Congrats! I love the way you mounted and configured the turbo. More pics and video!
Thanks. The original goal of the VH project was to push the engine to its stock mechanical limits like the KA, which I may still do.T45 wrote:Damn Jeff, you should post up the vid of the stock KA dyno. Unbelievable. If you hit that much with the KA I can't wait to see what the VH does on stock internals.
I've been tuning the stock 8-bit ECU for boost using the stock injectors and MAF in a blow-through setup. The AFR's in the top-end are a steady 11.8:1.qsiguy wrote:Jeff, what tune are you using for your ECU? Have you retuned it for the boost? I know you had a good tune for NA but curious if you've done anything yet or just using the original tune still. Using 8 bit or 16 bit ECU?
Hoping to pick yer brain..... and maybe beg steal or borrow a copy of the map if you've made a decent one for 6 psi....
Oh, and are you monitoring the a/f ratios? If so, how's it looking with the tune you're using?
Holy cow, 30psi on a stock internals!
