I would imagine for the cost of putting a LS motor in a Q you could turbo with 6 lbs of boost and retune for less money... Then again it all depends what you want... I bet you'd be looking at very comparable money for an LS series motor/trans/wiring and someone to install vs someone installing 2 turbos and tuning it..
IMO its stupid to talk about paying someone for labor, because who's actually gonna do that to a nissan/infiniti.. Maybe part of it, but i bet NO ONE on here is gonna pay someone to do a project on here start to finish... IMO anything in this thread that you cant do (not because of tools but because of knowledge), then you shouldnt be doing... know what I mean?
BTW even with full price labor my friend wanted to charge me ($1500 for labor only), still 1/2 the price of rebuilding my level 10 or going OEM... So i'd say its cheap..
Orphan wrote:To end on basically you need to understand upgrading your Q is really a waste of money, even if you picked up an s13 and dropped a VH in it would be much better, the original S13 is only around the 1100kg mark, thats 600kg+ lighter than a Q which makes a HUGE difference, even a stock VH45 in an s13 can be quick.
Again, it depends what you want. Who said he wanted a fast rackety racecar? what if he wanted a fast luxury car? BMW does it, why not make an infiniti do it?
I really think a centrifugal SC would be stupid on a VH. It needs something that needs boost at lower RPMs, not high so much. centrifugals work great on big block motors, not so much on tiny motors with oversize valves.. Roots/screw type or a couple little snails would be the money shot IMO..
BTW a stock Q45 with the AT, ECU, and headers (about 270WHP) will do 14.1 @ 99MPH... and the Y33 weighs even less by a couple hundred pounds... 340WHP should put you deep in the 13s, which isnt bad.
