450sxtc wrote:What are you talking about when you say the "quench area", the lower edge of the rod at the 10 and 2 oclock positions over the crankpin??? I was working off of the fact that this motor has pretty close to a perfect rod ratio and going with another aftermarket rod, one that is already produced, that is slightly shorter and could be machined to fit by removing a very small amount of the material, would give this motor almost a perfect rod ratio which is a key element in race motors.
450sxtc wrote:Hey you guys ever consider making some oil squirters??? That's what I'm doing. Tapped into oil pressure and I'm going to fab the squirters with peices from KA blocks that I have laying around. Also, any of you ever pay attention to the rod ratio of this motor??? You don't really have to get pistons made. Try reconsidering and playing with the rod legth. If you can do the math, you'll find that there is a set of rods for another engine out there that can fit into this motor with a little machining and give it a perfect rod ratio and retain the shape and size of the stock pistons which promotes for great torque under boost at low rpms. Swirl polishing the tops of the pistons helps to. Also, if you use the correct internal combo you will have that perfect rod ration which will balance power and torque evenly and and still allow for hella high rpms and less piston to valve interference, and this is good for all of us who seem to enjoy boost and know our motors have weak timing chain guides and such.........just putting in my 2 cents. enjoying reading the post.......Nate
