Thanks tech... I appreciate your reply... I dont thikn one could drop the oil pan 1 inch without hitting the cross member... I personally feel that its adequate but someone else with a modded VH45 was telling me the "front sump" design is no good... The only thing I dont see why it would make much difference, because the oil cant go to the back unless you held it vertically.Q45tech wrote:And which team of engineers will spent the $500,000 necessary to redesign it.
Road clearance is a problem as we must have changed a dozen oil pans and a like amount of engines from hitting and damaging oem.
Note what Stillen did for V6 3.5 just build a 1" spacer to drop pan and a 1" extenstion for pickup tube.........extra volume without redesign.
Easy! Convert to a dry sump.qship96 wrote:would love to find a way to get oil capacity to 9 quarts.
maxnix wrote:Easy! Convert to a dry sump.
You could add a reservoir after a cooler and remote oil filter (if you position it right you could fit a massive filter in there). Not a whole lot of room though, -make a custom reservoir to fit?qship96 wrote:would love to find a way to get oil capacity to 9 quarts.
Not trying to pick a fight, but why?qship96 wrote:would love to find a way to get oil capacity to 9 quarts.
I was thinnking the same thing, front sump is bad for drag racing, but with baffles and the real world use of a Q, it's a non-issue. Though when Dr. B was running that huge shot of nitrous, he may have experienced a few seconds of decreased oil flow, but not starvation.RobertsnewQ wrote:I think it's a damn good design compared to some others - that's some pretty trick baffling for an OEM pan. But yeah, front sump blows for drag racing.
Think about it - when you accelerate all the oil wants to rush to the back of the pan. That means away from where the oil pickup is...
A stock Q will never launch hard enough for it to make a difference.
If it bothers you, just get an Accusump.
There is space between the "baffle plate" (really more of a windage tray) in the diagram and the sump (the deep area). The cover over the sump is the real baffle in that design, and it has holes in the back too. That baffle plate won't stop much oil from crawling out of the sump in a high-g situation.elwesso wrote:Notice in the above picture. there are holes in the baffle, and they are only in the sides, so oil cannot really go out of the lowe area during braking or accleration.
I agree, since it would take 1 G of accelleration to uncover the sump appreciably.Elwesso wrote:IMO, the VH45, even with boost, cannot cause a Q45 or any other vehicle to accelerate so rapidly for so long that oil starvation becomes an issue.
That will be much appreciated.John Dixon wrote:I should have my dry sump pan back this week from the fabricators, can post up some pics when it's done. Using the stock baffle plate but with scrapers added to the back of it.
Not sure to be honest, it does look pretty good to me. I'm guessing the Q is not the sort of car where you'll be generating a lot of conering force, which was my concern and the horizontal baffle should keep a small amount of oil around the pickup for short bursts.Biggest concern would be sustained hard acceleration I guess. Think the only way you'll know is fit a high pressure oil p. warning lamp/buzzer and watch it carefully when you're driving.You could always fit an oil pressure accumulator, but again it's only a transient thing.elwesso wrote:John, do you think the stock VH45 oil pan is decent enough for mild boosting and stuff like that?
