VH45DE: Hidden Beauty of Intake
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
anlasak wrote:
She will be getting a supercharger, a manual gearbox, and a few add ons. I'm also going to enlargen the intake passages a bit over stock to allow less restriction. Even a little less restriction will be a benefit for me.
by all means.... go on.
Raxephon
Car: '04 RX8...for the moment...
elwesso wrote:by all means.... go on.
I will................as soon as I have more finished and a few pics to go with it.
elwesso
2007 BMW M Coupe
at least whet my appetite with:
Blower: (i dont care brands, i just want to know roots or cent.)
and
Transmission (most likely Z with who's plate?)
Raxephon
elwesso wrote:at least whet my appetite with:
and
Custom centrifugal and a custom bellhousing on a FS5W71C.
elwesso
2007 BMW M Coupe
thank you....
BTW, ill see you at the other end of the tunnel, antonio....
darinz
Car: Nissan Patrol
I've just cut up the stock exhuast manifold with the look of modifying it to fit. (in a Nissan Patrol). And to be perfectly honest, they are crap in side. From the outside they look pretty good but where each runner attachts, there is a hole cut in the pipe that in no way coresponds to the size of the runner. Apart from the front cylinder on each side, they are getting a lot of restriction. Even a budget pipe manifold is going to be better!
elwesso
2007 BMW M Coupe
so where do yo uthink the most restriction is?? It appears that the flange and the turndown is all good, and then after it dumps into that tiny little runner, it looks pretty restrictive.
So really if you wanted to modify it youd just take the manifold and cut everything off except where it turns down.
darinz
Car: Nissan Patrol
From the flange to the first weld is pretty good. It is what is behind the first weld that is the problem. I've cut everything of the flange and will start from there. My original plan was to trim things up as I'm putting a VH45 into a Patrol and there isn't enough room between the chassis rail for the factory manifolds. Now I'll just make up some cheap extractors. The problem is that in after next season I'm going to turbo it so spending the money would be a waste.
That intake is a work of art. Its something nice to think about the next time I hammer it to 120.
Return to “VH45DE / VK45DE / VK56DE Forum”
