VH45 to VG30 Adapter Plates now available
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
vh45dettz31
Car: z31hopefully soon to be z31 with a vh45de
Are these adaptor plates still available?Thanks Jake
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yes they are
phongshader
I tried to pm you...
I want to adapt a Porsche trans to a vh45de. Kennedy Engineered Products makes a flywheel and clutch that is compatible to mate the two but they only make an adapter for the vk. Would you be willing to give me the vh bolt pattern dimensions/make an adapter?
Thanks
elwesso
2007 BMW M Coupe
I actually do not have an engineering drawing of the vh bellousing that belongs to my machine shop.
If I could get the Porsche trans bellhousing i could probably make an adapter?
phongshader
Nissan V6, 3 Liter, 300 ZX, Maxima, and early Pickup. Specify 6 or 8 bolt crank.
This flywheel will bolt up to a vh45 correct? If so I need to find out what the thickness of the adapter plate made by Kennedy is, they won't make a custom adapter for the vh. I'm sure I can find bolt pattern dimensions for the porsche bellhousing online somewhere it's been the same for 40 years. What would you charge for an aluminum adapter plate?
norCalSmokey
Hi, are the plates currently available? I'm in need of one for my VH swap. Thanks
elwesso
2007 BMW M Coupe
Yep I have one ready to ship. Send me an email
norCalSmokey
Just emailed you
norCalSmokey
Hey, just wondering if you got my email?
bkg775
Car: 1991 Nissan 240sx
Just emailed ya
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
Are these kind of like the xcessive adapter. They look really good quailty, and I would commend you for making such a good item!!!
Geoffs89Pathy
Car: 1989 Nissan Pathfinder, SASed(chopped for parts)
1991 wd21 D44 coilovers, bumpers, lots more..
unless they were redesigned they take alot of home modifications to work correctly
fluffybunny
Car: '90 300ZX
'90 300ZXTT
'90 VW Fox
'97 Legacy GT
'05 Audi S4
'10 370Z 40th Anniversary Edition
I have one from the first real batch, not the prototype ones that Geoff used and it fit quite nicely. Two of the holes used for mounting the transmission to the adapter were irrelevant as they did not protrude all the way through the bell housing. The adapter did feel solid using 7 of the 9 bolts. I drilled through the transmission flange south of the starter for a little more support on that side, so I'm using 8 of the 9 included securing bolts. I see no problem and think it's optional whether one would feel inclined to do so themselves. The only problem I found was the two holes for the alignment pins, from the back of the engine, were super snug and I had to use a dremel to open them up a smidgin. Also, one of those pins interfered with the transmission, not letting it sit flush. So a tiny bit needs to be filed out of either. This is a disagreement of engine and transmission though and has naught to do with the adapter plate.
fluffybunny
Car: '90 300ZX
'90 300ZXTT
'90 VW Fox
'97 Legacy GT
'05 Audi S4
Oh and make sure those bolts are all parallel when you weld them in place or you are going to be kicking yourself later.
elwesso
2007 BMW M Coupe
I feel bad for Geoffs89Pathy because the plate he had did not line up properly, as he was in the initial run. I offered to send him another plate with the correctly aligned holes, but did not want to do that route again. I also think a lot of his trials and tribulations during the install process were done improperly, however they were all mistakes that anyone could have made.
Also note that when mazworx made their first adapters, there was a bolt hole on the block that was almost half a hole off.. Its all part of the learning curve.
On the note that Tommy made about the bolts lining up when welding is very important. Another member made a suggestion to wrap the bolts with wire or something to ensure they are centered in the transmission holes.. This person said that trick worked like a charm.
The bottom line on these plates is that I know they aren't perfect.. The fact of the matter is that when they are setup properly, I believe they are superior to mazworx, AND they are about 1/3 the cost after you factor in machining the bellhousing (regardless if you send it to them or have it done locally)
Most guys that are going to be mating a 300ZX transmission to a VH45 have more than enough skill and capability to make this adapter work, which is why I am able to offer them at a low price. I am not doing these things to make money, I make a little for my time but I don't make a living on them. I try and be as honest as possible making sure everyone knows the pro's and con's...
LAURELVH41DE
Car: 1993 C33 LAUREL 4DOOR HARDTOP
RUNNING STAGE 1 VH41DE
HEY THERE ARE THESE PLATES STILL AVAILIBLE????
I HAVE BEEN RESEARCHING AND I RECKON THIS IS THE BEST KIT ON THE PLANET
I DONT LIKE THE IDEA OF A BIG ALLOY SPACER OF THE CRANK.
CHEERS GUYS
elwesso
2007 BMW M Coupe
Yea I still have them available
inteleric1983
Car: SRT4
Also interested in one. Pick up my vh tomorrow.
How do I buy? What work will be required?
elwesso
2007 BMW M Coupe
Just send me an email. :)
88 P-body
Could you please send me an email? I can't seem to find an email address for you. I have some questions about your Adapter plate but want to discuse it via email. nelvar42 AT Hotmail Dot Com
thanks in advance
Joe N.
inteleric1983
Car: SRT4
elwesso wrote:Just send me an email. :)
I searched for your email in your profile, but it isn't there.
My email is inteleric1983 at yahoo dot com
Thanks
Eric
elwesso
2007 BMW M Coupe
Sure I'll send you guys emails. For reference my email address is on the contact page of q45.org
LuckyRps13
Car: 91 S13.5 240sx
I may end up picking this up in the new year.
zapracing
Car: 1993 240sx
I Vant Vone. how do i get one. [email protected] let me know.
lalo
Car: 1989 240sx and 1988 300zx turbo
do still have this adapter plates availeble let me know at [email protected] thanks alot
elwesso
2007 BMW M Coupe
Replied to both... FYI my contact info is on www.q45.org.. :)
s13-dream
Car: 92 nissan 240sx hatch
i know this post is old just woundering if u still make the adaptor if so what are shipping charges to tucson az
elwesso
2007 BMW M Coupe
Shipping is included. Send me an email to [email protected]
Gussg
I'm interested on your adapter plate. Still available?
Awesome job :dblthumb:
elwesso
2007 BMW M Coupe
Yep!
Return to “VH45DE / VK45DE / VK56DE Forum”
