Post by Chaluska » https://forums.nicoclub.com/chaluska-u25522.html Fri Mar 30, 2012 11:56 am
Yes, so long as you have everything hooked up to it... you will HAVE to tie the harness in with the stock S chassis harness.. otherwise it wont fire up the fuel pump, give the ECU power, etc etc...Bristol wrote:ok so swap is almost done... i need to know if the stock untouched wiring harness on the engine will be enuf to atleast start the car.
Post by speedeast » https://forums.nicoclub.com/speedeast-u139789.html Sun Apr 01, 2012 8:13 am
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
