Chevy 350 is 90* FYICarl H wrote:chevy 350 fits in there really well with ample space to the sides...but then again its a 60* v8...vh is 90* + twincam heads.take some measurements!
A few days ago I would have agreed with you.. but fortunately for me the RX7 has a simply huge transmission tunnel - aided by the fact that the cross member is spaced down about 1" (engine sits lower). I'm actually starting to think I may be able to close the bonnet after removing some of the pesky reinforcing on the underside!elwesso wrote:I dont think it will fit without modifications... I bet the bellhousing needs clearanced as well as the alternator.
Not insurmountable by any stretch of the imagination!
It fits in an '88 FC just fine.Wes M wrote:Will a VH45DE + Auto fit into a Series 1 RX7 Chassis??
Answer will be posted tomorrow (with pictures).
Wes (another one)
Haha not much gets past you! It is indeed a rear sump - my first attempt at welding sumps.. I simply cut the flange of with a cutting disc and spun it around 180degrees and MIG welded it back on. There is a change in width of the sump on one end so you need to weld a couple of strips of sheet metal in. All in all very straight forward. I'm very happy with how it turned out, no measureable warpage. Did a quick with dye penetrant for leaks and plugged those up...Orphan wrote:And is it just me and my vision that see's a rear sump on that thing :S I'm guessing its custom as I can see welds :P Got any more pics of it? I need a rear sump set up for my eventual transplant and dry sump is a bit too costly atm.
Does this help?Orphan wrote:Any chance you can measure the width between the rails and the width between the towers for me?
Indeed. There is already a considerable amount of steelwork reinforcing the chassis from the firewall back. Looks not unlike the Auckland harbour bridge under there! This was all part of the original convertable conversion. From the firewall forward I am adding additional steelwork under the chassis rails through to the front of the cross member. This was initially intended as a spacer to lower the cross member/engine, but by welding it to the rails it will also give extra support. There will be a new strut to strut to firewall brace to replace the one I have taken out. The plan is also to install a roll bar which will incorporate some extra bracing to help stiffen the chassis up. But I want to keep this as discrete as possible - not wanting to drive around in a jungle gym.Mettler wrote:I hope you reinforce the shell, I'd hate to see your car banana really fast from the torque
Thankyou!Wes M wrote:If one of our kind moderators sees fit to change the thread title to something more informative ie VH into Rx7. Then I shall do my best to keep this thread up to date with my progress.
