Thanks Orphan, yeah progress is coming along nicely now... My vacuum assist clutch setup should be done in the next day or so.
Re the VQ30DET, my brother is nearly finished a conversion putting one of these into his Cefiro. His Cefiro origonally had a VQ30DE which wasn't quite enough so he brought a VQ30DET engine to put in. He ran into some issues with his block being FWD and the new engine RWD so the mounts didn't bolt up. In the end he used the turbo etc on his old block therefore making it a high compression turbo.
It still needs a bit of tweeking to get it right but it already seriously hauls a** - and that's in a cefiro which isn't exactly light.
I'd say either engine would be wild in the FD. The VQ has benefits of being newer but I've noticed that gunking up in the valve train area seems to be a common problem. Both my bros engines required a spoon to clear the crap out - seriously he spent days getting all the crud out. Fortunately they dont use hydraulic lifters. Just be sure to check carefully before buying!
