vh45 dyno
gs14racer
Thought you guys would be interested even though you hate dynos lol
specs
vh45de in a 96 240sx300zx 5 speed12 lb flywheel12 driveshaft
intakeheaders 1 3/4 primarys with 3 inch merge collectors3 inch dual exhaust with x pipestock ecu
NOR*CAL 916
Car: 1994 infiniti q45
what are the horse power/torque numbers?
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
I don't hate dynos
Looks strong
Thanks for sharing. Now we'll need some pics, please and thank you.
gs14racer
numbers are 273 wheel horsepower274 wheel torque
Dont make fun of the duct tape you have no idea how diffiicult it is to find a 3.5 inch silicone coupler at 4pm on a sunday.
94infinitiq45
Hey i am actually looking to do a 6 speed conversion in my car because the automatic has too many dead spots. Which clutch and flywheel did you use and also what did you have to do with the bellhousing to get it to work?
NOR*CAL 916
awesome build, do you have MPG figures?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
NOR*CAL 916 wrote:awesome build, do you have MPG figures?
Dont take this the wrong way, but who cares about MPG?????
This is a Nissan 240sx with a VH45 and you're worried about MPG..... 275WHP on a STOCK VH45 with just headers. STOCK ECU. Proves that headers do the VH very good and the AT sucks down a lot of power!!! Probably putting down 320-330 flywheel HP and we havent even gotten him a NICO ECU. Will probably see 300WHP with the ECU, at least I hope. His AFR's were pretty rich, the NICO ECU should put him the 15:1 range which ismuch leaner than the 12-13:1's he was having.
94infinitiq45 wrote:Hey i am actually looking to do a 6 speed conversion in my car because the automatic has too many dead spots. Which clutch and flywheel did you use and also what did you have to do with the bellhousing to get it to work?
lino
Thanks for the pics! Looks awesome and best of luck with it.
The headers look sick!
elwesso
2007 BMW M Coupe
Heres the build-up thread!!!!
zerothread/231283
gs14racer
yea gas milage aint high on my priority list with this car
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
Hey, to me a VH45 is very much an economy engine. I tried for way too long to figure out a way to put one in my '69 mustang. The engine I have built for it is a 514" ford V8 (and looks like it'll still be going in the car). 4.5L would have got me much better mileage than the 8.4L ford. And to think, a 514" is a medium size motor to the big block ford guys. A "big" engine is generally anything from 600" to 800+ci. Just putting it all in perspective...
Q45tech
Curious as to why you opted for such long tuned header pipes to peak the torque so low in rpms?
qship96
Car: 1996 Infiniti Q45
torque peak looks to be 4750 rpm or so,you consider that low? isnt stock peak at 4000rpm?
Q45tech
http://www.bgsoflex.com/bestheader.html
Without inside runner diameter and exact length from exhaust valve to collector it was just a photo guess. 39-48"
Fill in your numbers and report what the software says. Obviously the software can only be right +-5% length due to cams and stroke variances.
elwesso
2007 BMW M Coupe
Good link tech, how does that work?
gs14racer
the runners are 31.5 inches long give or take a 1/4 inch. As far as technical aspects are concerned i modeled them after some pics i saw on line. dont know much in the way of the technical jargon, looks better than stock though.
gs14racer
this is the number it gave me by the way
The best header tube length to use is: 23.930029
Rex
Car: None
elwesso wrote:... Proves that headers do the VH very good and the AT sucks down a lot of power!!!
I agree with the first part, but what makes you say the second part?
Are you thinking I'm losing 20-30 more HP than him due to the AT?
Just curious about your logic.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Awesome! I love dyno sheets. It looks like you have about 30 more RWHP than Lola. I need some headers...
I bet that intake pipe helped with the power, too. Straightening out the intake and exhaust really helps with the power on these cars.
When I get my new welder, I am going to attempt some headers on the car. Maybe, if I get good at it, I can make a few sets. I need to make a set for the GMC V6.
I want to make a true fresh air intake for the car with no restrictions like the factory box, too.
elwesso
2007 BMW M Coupe
Maybe not but it just seems that hes' making as much power as your car is without any ECU mods.
