VH Hot rod
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
Rex
Car: None
Thanks, I knew there were pics of this somewhere
Click for a larger version
WDRacing
The MAF translator is the same price as the MSII which is a full standalone.
Qucifer
Car: 1977z, 1982zx, 1983zx, 1982 sentra, 1996 sentra
How about putting the VH in a 240 - 280z. Thats the way to go.
WDRacing
Because hybrids is for people swapping a Nissan/Infiniti motor into a non-Nissan/Infiniti body, or vice versa. Its explained in the welcome thread.
Besides, we're obviously discussing a Hot Rod, hence the title, VH Hot Rod.
WD
Here's what we need to do:
zerothread/224610
Brian, when are you gonna come up one weekend and spend a couple days in the garage with us?
rotorimp
Car: 02 Xterra, 60 IH Metro
It does allot more than just translate a map/temp signal to MAF signal--and the price (for what it does) is pretty reasonable.
check this outIs the ultimate in bolt-on tuning mods! The Translator Pro performs a true speed density calculation to determine engine airflow, allowing the user to remove the MAF sensor and use a GM 3 or our 5 bar MAP sensor. Allowing tuning by RPM and boost, the Translator Pro is pre-configured with base maps for most popular applications to get the user up and running quickly, just select the base map, injector size, and go!
I wonder if there are any VH,RB,SR ect... maps in there.
It is very capable (data logging)--I'm considering one of these for tuning the rb and I like that you can pull it up on your lap top!!
The Sensor monitor page is used to view various sensor and signal values. Each button toggles one of the 4 viewed valuse through the following list.
RPM - Engine RPMMP - Manifold presure (KPA)DC - Density Compensation (Speed Density Airtemp correction factor)AFL - AirFlow, Speed Density calculated Grams/SecAFI - Airflow Input, If a MAF is connected.VE - Volumetric Efficiency, from the Speed Density algorithmFI - Frequency input valueFO - Frequency output valueUT - User Tune. Combined System Scale, AF Tune, Airtemp, and Triggered adjustmentsTPS - TPS sensor valueBD - Boost DutycycleMT - Manifold TemperatureO2 - Voltage reading on O2 sensor inputFE - Flow Error. If a MAF is conected, this is the % dif, MAF and Speed DensityASC - Afterstart correctionAFR - A/F Ratio, if a wideband is connected.CF - Wideband tracking Correction FactorTAF - Target A/F Ratio
rotorimp
Greg----mmmmmm--that pic makes me happy in pants!!!!
BTW--Just like jello--there is always room for another project--WE have over an acre to fill up
Qucifer
WDRacing
HOLY CRAP...I think I'm in love...That would be AWSOME in a Hot Rod!!!!
Those welds are amazing...
rotorimp
Yea those pipes took about a metric crap ton of hours. When I was putting Greg's intercooler pipes together it took me about a Day each pipe. It was all pre-bent and all I had to do was tig it together and it took a whole day!!!! It gives me inspiration for my RB piping..
As cool as forced induction woudl be I still would keep the Hot rod NA--JUST because of the nature of the project---AND the reason I started this thread was I was running those VH's without exaust.
WDRacing
It was more of an inspirational post anyway. A sweet open header VH would be almost as sexy as a set of twins.
Have you considered the 6-71 blower? It wouldn't be "to" hard to ring up. Then you'll can toss on a Demon carb and roll. That with open headers...dude. Plus, the blower whine at 7200rpm would sound like pure sex.
WD
rotorimp
Any of the refined V8's sound sooooo Good no matter what you do to them--If I carbed it up I wonder if it would lose that distinct sound?
WDRacing
I doubt it would, plus you could fab a really nice high rise intake mani for the carb. Although, I am against going carb...What would you be using for ignition control?
I like the idea of a high-rise or ITB's for the VH... Remember those ones from AU we saw at SEMA?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I just wonder if the VH sound has anything to do with the way the intake is designed because youll notice that even northstars, and ford 4.6s dont have that "sound" the VH45 has. Its very similar, but its not the same....
WDRacing
ITB's would rock...
rotorimp
Porsche (late 70's and 80's)did allot with port timing, valve timing and port tumble and flow--they dramatically increased HP and the resulting sound of the Porsche V8's and flat 6's are VERY distinctive because of this. It probably does not have as much to do with plenum volume as it has to do with the mechanics of the head and timing of the combustion event.
WDRacing
Well there you have it, go find a Porsche V8 or twin turbo 6...
rotorimp
Because Porsche motors are Stupid expensive!!!
I want to use as many Datsun/Nissan parts as possable--I'm going to plunder Gregs datsun roadsters for controls and suspension.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
AZhitman wrote:I like the idea of a high-rise or ITB's for the VH... Remember those ones from AU we saw at SEMA?
THOSE WERE SOOOOOOOOOO SEXY!
And some sexy Rousche stacks:
Also, here's some pics I took of a rod there:
Loved the way they set up the aft, looks really slick!
-Dan
rotorimp
Yea those are pure Sex!!!
Remember the price
Dano
Yeah, I could maybe afford 2 of the horns, maybe.
-Dan
Return to “Hybrids”
