Okay so here is what I got done to it, he assembled the block, heads, cams, etc. and I will be putting the rest of the stuff back on myself.
Total for job 3.5K:
Wiseco Pistons and Rings
ACL Racing Rod Bearings
ACL Main Racing Bearings
ARP Connecting Rod bolts
ARP Main Stud Kit
ARP Head Stud Kit
Supertech High Temp Valve Seals
Supertech Valve Springs
Cosmetic Metal Head Gaskets
Degrease Inspect
Square Deck Block
Align and Hone Mains
Chamfer and Polish Crank Shaft
Bore and Hone Cyls .20
Re-size Connecting Rods (decided to keep stock)
Resurface Heads
DOHC Valves
Balance and Rotate Assembly
Assemble Engine: Heads, Rods, Cams, etc.
Before:
After:
Before:
After:
What was done to engine before blown piston:
HKS Intake, Polished intake manifold, 3” cat-back exhaust, high flow mufflers,
Greddy Profec Type-S boost controller, JWT performance programmed ECU,
Lowered 1 ¾ in, cross drilled rotors, JDM taillights and aftermarket rear spoiler.
Services:
Clutch and flywheel (26K ago)
Replaced Shifter bushings and sleeve (20K ago)
60K service, new tires, timing belt, & water pump (18K ago)
Replaced cam sensor, hoses, 27 point inspection, brakes flushed, air filter, bulbs (16K ago)
New battery and oil/filter change (12K ago)
Oil change, 27 point inspection, pass window motor, pwr antenna (8K ago)
New water pump (5K ago)
New starter (3K ago)
New 149 mph tires (1K ago)
New brake pads all around (1k ago)
What I have purchased:
N/A Oil Squirters (3)
Nismo 555CC Injectors
OEM Gasket kit
BDE Exhaust Cam Valve Cover Plugs
Purchasing in the coming weeks:
2.5 SZ downpipes and test pipes (scrapped my stock ones for $ towards engine lol)
EGR delete kit
02 sensors
NGK spark plugs
I pretty much just wanted to pull the engine to get rebuilt and put it back together with the same parts because it's in great shape. Then upgrade the parts that caused the engine to blow before, which was the previous owner turning the boost up too high with stock injectors. The stock turbos are in great shape with hardly any shaft play, I got them checked out at the shop. Over the summer I plan on getting Mike smith manifolds and bigger turbos, but all my money has gone towards rebuild so I can't get them now lol. So I'm starting to save now for that stuff but I wanted to get some more miles out of the stocks since they only have 78K on them and are in great shape.
Questions:
The previous owner put a JWT ECU in it, but now that I got bigger injectors do I just need to order a Eprom chip with my specs and put it in myself or will I have to send the whole ECU out?
With the few upgrades I will be doing, will I need to upgrade the clutch and flywheel with the added power?
What boost should I be running once I get her running?
I appreciate any feedback and suggestions towards other parts I should get.
Thanks in advance, Pete.
