Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Fri Jan 09, 2015 11:24 am
Sorry, I must have misread your question, and/or only answered half of it.
There is a tolerance for the coils, and it can be found in the FSM, but the easier way to do it would be to wait for it to "act up," and then pull connectors one at a time, and when you find the one that doesn't change anything, that is your culprit cylinder. When you find that one, swap the coil pack with another coil pack and see if the problem moves to the new location. If it does, it'll be a coil pack. If it doesn't, more than likely injectors.
But IMHO, if you are losing all your fuel pressure on a new pump, that'd be a different issue than a stuck injector, and you'd most likely be flooding a cylinder completely to the point of fuel coming out of the exhaust and having a noticeably wet spark plug.
Could you post a picture of your current fuel delivery setup and/or a diagram? I'm having a hard time visualizing the setup without it actually being in a Z32, haha.
