VG30 swap
Discuss topics related to the VG and VE series engines.
nick_gstn
Car: 1995 Nissan 240sx se
Has any one done such a swap into a 95 240sx? If so what problems did you run into and how hard was it to do?
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Are you thinking of the VG30E(T) or the VG30DE(TT)? I've seen an S13 with a VG30E(T) and they are compact enough that it appeared to fit beautifully. They are pretty lightweight even though they have an iron block and are a bit lower and shorter than the KA, which could give it better handling characteristics.
On top of that, they are very strong stock and can handle boost very well. You can also bolt on the near bullet proof Z32 5-speed with a 89-91 Maxima flywheel and either a Maxima or 84-86 300ZX Turbo clutch kit (you will need to use the Z32 throw out bearing though).
The VG30DE(TT) will be a little more difficult as it is much wider but I've seen it done in, I believe, both the S13 and S14. I'll have to look around for the pictures and such of those though, its been a while since I've seen them.
200zx
I put the vgdett into an s13 s14 should be an identical install there are plenty of examples knocking round the net I tried to put up a pic of mine but it wont let me dooohhhhh
http://img.photobucket.com/alb...1.jpg
mtcookson
1992 Iinfiniti Q45
and much much more
You can send the pictures to me at mark at machzracing dot com and I can host them for you.
dillards1234
Car: 90 240sx hatch,95 Mustang
but what intercooler would you use for this swap??
FoxFire
Car: 90 vg30eT 240SX, s12 vg30e
zerothread?id=260485
im doing an s13 swap...
im not done but as i go, im writing the guide
PBfrEAk
Car: '00 Frontier (Newb) '92 Maxima (Daily), '93 Max (Donor), '91 Max (Project) '77 F-150 (Funmobile)
You should be able to use whatever intercooler you want as far as brand name goes.
I'm sure most make coolers to fit any application. It's just up to your own personal preference.
Return to “VG30 / VE30 Forum”
