stocker240 »
https://forums.nicoclub.com/stocker240-u34457.html
Fri Feb 08, 2008 11:22 pm
Buddy i am going thru something totally simmilar and i was gonna put up my own post but because of the similarities i figured i hijak yours
for the last few weeks i have noticed a few small drips of coolant on my driveway at home, ive been checking and adding coolant whenever needed
so the other morning i am on my way to work and ive warmed my car for about 5 mins and ive been drivign for about the same and i notice that all im getting is cold air thru my heater
my temp gauge read normal so i kept going , a few minutes later it was blowing hot air
20 mins after that i had to pull over because i was nearly overheating, i was on the enterance to the freeway so i couldnt turn around after 2 mins of driving the temp read normal so i went to work ,
i got to work and checked my coolant level at the rad at the end of the day, it was down so i jacked up the front and ran it with the cap off and topped up the system with water
i ran the car with the cap off and the heater at full until the water level stopped dropping and the heater blew hot
i drove the car to my shop with no probs, once i had the car inside and shut off i saw the water pump **** the bed and let got all over the floor, i drained the rad, installed new water pump, thermostat, and pwr steering to fan belt. i got everything buttoned up and double checked the drain c*** at the botom of the rad, gave it a twist and it sheared off ,,,
next day got the drain plug from nissan, got the system filled with water only, the car is jacked up and the rad cap is open , same as before water level isnt dropping and heater is blowing hot i drain the rad , close it up and fill with coolant and water mix, jack it up and run it till it blowing hot
the thing is same as you my lower hose is cold . i mean COLD, so is the lower 80 % of my rad , i figured air lock so i went to loosen my bleeder bolt on the intake and busted that as well , time for a break
so after 30 mins of running the car all seems good and i am on Empty so i make a run for the gas station and all of a sudden overheating
back to the shop back in the air and still the lower hose is cold
i ran it for at least another 30 mins the hose is still cold but inside the temp reads normal and its blowing hot
after a long day and at least another hr of bleeding, i put the rad cap on and went for a road test , 20 mins later and no probs temp is perfect and heater is blowing great.
i am confused at this point because both nissan tech's that i spoke with said that the hose should be warm and it definately isnt
i stop and check my levels once again and the rad is down abit and the overflow bottle is empty , i top them both up and bring a few jugs with me and go for a good hard run , at least a 30 min road test everything seems perfect BUT the hose and rad are cold
ive decided that for tonight i am more comcerned that my car not overheat and if that lower hose is gonna stay cold, im just not sure
if the car comes close to overheating again i am gonna pull the rad and send it to be checked for blockages and go from there
the car is a 1991 fastback 5 spd with hicas 220 kms ive owned it for 2 yrs , havent had any major repairs or done much more that regular tune ups
thanks Josh
