vancouverbc wrote:hot coolant from engine flows to top of rad and works its way down to bottom and leaves bottom hose and goes back to rad
.ho
hot coolant goes from engine to top of radiator.
then leaves bottom hose and goes back to radiator?
i didnt know the coolant sits at a stand still....
top hose goes to rad, bottom goes to block.
also, thought id mention this, from what ive done so far, the headgasket replacement seems to have fixed the overheating and leaking freeze plug ordeal.
after i adjust the timing some more, ill be able to know for sure. but i was cruising earlier and it stayed right in the middle of the temp gauge.
vancouverbc wrote:cold outlet could mean blocked rad but it could also mean the rad is very efficient.
^ is that true?
