Im very happy in the sense that the RB swap has the ability to scare alot of people away because there are no retarded how-to step by step guides out there.Carl H wrote:no.do the research, its all there...no one likes holding some one elses hand.
premade stuff is also about 1000$ more expensive lolpirate87 wrote:haha, very detailed write up........that would take all the fun out of the swap! I think the easiest way to do this would be to buy all your pieces pre-made (mounts, harness, etc..) and then get the RB25 FSM. There's a detailed section on engine removal, follow that in reverse. Assuming that you properly preped the RB and didn't destroy most of your old KA stuff upon removal, you should have no problem.
Honestly that about as concise as you are going to find, everyones already said it, but the info is out there just scatttered...
You need a Silvia clip (SR20) to have the right parts to convert a 240 to RHD. A friend of mine did it with a S13 coupe. He happened to get a clip with a perfect dash and door panels, so he did it. Had to cut the firewall out and weld it into the 240.This is his website http://www.slidestyle.netReefwater wrote:could i get the rb25det front clip from jdm-online and convert an automatic 93 240sx into a right side drive maunal with this clip package???
that one comes with a rb25 transmission, so it would be RWD.Reefwater wrote:what do you think of this offer: http://www.jazzproparts.com/Pr...ranny
could i get the 26 and not have the awd problem and be able to stay rwd???
Yes.. but you will have Gawdzilla lurking under your hood waiting to breath fire with the slightest flick of the accelerator pedal!!!Kamin wrote:p.s. that swap needs about $5000 worth of other **** to make it work. you WILL spend $10,000 on parts alone for a Rb26 swap.
Yeah, but my version of 300 whp so waaaaayy cooler than your version. Plus the RB26 will make the fanboys wet themselves!Even more.. If you have a RB26 you can put a GTR badge on your 240sx!Kamin wrote:no, youll have about 300whp.
eh ill save myself the 6000$ and put it into the rb25. and have 400+whp, daily driven. and still have 2k leftover lolEikon wrote:
