RB20DETodd
I stole a DC-10 wing and put it on my car.
Green 92 s13 coupe SE Rb20det
Honolulu LAND OF NO PARKING HI
4-8-2005
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 10:21 AM 7/12/2006 |
lookin good, for the rb20 Ka mounts can be used WITh the R32 X member. Another small thing i had to make a custom Throttle cable bracket, no biggie though, another thing that would be GREAT is if confirmed information could be stickied, sparkplugs belts etc the interchangeable thread is helpfull but it would be nice to have confirmed info.
Joe
single cam s14
Tucson, AZ
2-9-2003
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (RB20DETodd) | 10:25 AM 7/12/2006 |
wont the RB20 bolt in using the KA crossmember?ill add the throttle cable bracket stuff, i had to fab one up too. as for spark plugs, ill try to find part numbers and add them in there lol bcpr7es for the 25 i believe...
Carl H
Supporting Member
1995 240SX SE RB20DET Powered!, 1995 Jaguar XJR...needs paint.
Charlotte NC
8-4-2003
rb20 bolts in using r32 xmember no other way unless a mount kit is used.
SHift_BOOM. Damnit. Doing an RB2X swap and scared of the wiring? Check out my thread in the RB section. Now offering VH and SR/KA/CA conversions!
Joe
single cam s14
Tucson, AZ
2-9-2003
| « Re: (Carl H) | 11:04 AM 7/12/2006 |
gotcha.
RB20DETodd
4-8-2005
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 12:08 PM 7/12/2006 |
As for the rb20 sparkplugs i went to sparkplugs.com lol and It showed these for the rb20 BCPR5EIX-11 im running them now, i was told heat range 6 is what i should get, id like to change these plugs out, whats the #'s of what you guys are running on your rb20's?
Bronze MFP
1987 300zx w/digital dash radness
Charlotte NC
6-4-2003
rb20 turbo elbow did NOT clear on my s14 swap, but i have the hookup from a guy in australia who can make a kickass elbow that clears. also the stock tach can work, but you have to take apart the cluster and adjust the potentiometer on the back of the tach. you also need an aftermarket tach or something that reads correctly to calibrate your stock tach to. custom thottle cable is requred, but easy to make from parts from a northern hydraulic store or someplace similar. *edit* dont forget to replace the timing belt pullies too. they are as important as the belt. if they fail, its as bad as having the timing belt breaki think all the swaps require adapters for the heater hoses. and i hope you like wiring :-/
XcreatureX
96 240sx SE
Easthampton but belong in San diego MA/CA
1-11-2005
thanks, that answered a few of my questionsSeth
Joe
single cam s14
Tucson, AZ
2-9-2003
| « Re: (Bronze MFP) | 12:18 AM 7/13/2006 |
| Quote, originally posted by Bronze MFP » | rb20 turbo elbow did NOT clear on my s14 swap, but i have the hookup from a guy in australia who can make a kickass elbow that clears. also the stock tach can work, but you have to take apart the cluster and adjust the potentiometer on the back of the tach. you also need an aftermarket tach or something that reads correctly to calibrate your stock tach to. custom thottle cable is requred, but easy to make from parts from a northern hydraulic store or someplace similar. *edit* dont forget to replace the timing belt pullies too. they are as important as the belt. if they fail, its as bad as having the timing belt breaki think all the swaps require adapters for the heater hoses. and i hope you like wiring :-/ |
do you have instructions on how to recalibrate the tach? that would be some really helpfull info and thanks for the info, clarifications ammended
skillzilla
6-8-2004
My RB20 dump pipe didnt clear either of my S13's, coupe or hatch, Zenki or Chuki. Im using TopHat mounts.Also, the headgasket is a good thing to replace while the motor is out, I did mine in about 1.5 hours no worries at all. In the car thats a whole nother nightmare.
Darius
Iowa
3-2-2003
| « Re: (skillzilla) | 6:29 AM 7/13/2006 |
Don't forget, if you swap the head gasket to a metal head gasket, get the head and block resurfaced. I figure I should be the one to speak up on that topic
Bronze MFP
Charlotte NC
6-4-2003
| « Re: (skillzilla) | 7:19 AM 7/13/2006 |
| Quote, originally posted by skillzilla » | | My RB20 dump pipe didnt clear either of my S13's, coupe or hatch, Zenki or Chuki. Im using TopHat mounts. Also, the headgasket is a good thing to replace while the motor is out, I did mine in about 1.5 hours no worries at all. In the car thats a whole nother nightmare. |
oh god, any and all work you can do on the engine outside of the car is 10x faster than once its in. Newbies, don't rush, do everything you can to the engine while its out of the car!
ZenkiOwns
Cereal box of doom
Hanahan SC
7-9-2006
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 10:44 AM 7/13/2006 |
Any info on recalibrating the tach would be VERY helpful.I'm running an rb20 in my s13 and am using the SAFC II for a tach as of now.
lucky7
97 RB25 S14
Oakland township MI
5-3-2005
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (ZenkiOwns) | 11:03 AM 7/13/2006 |
tach recalibration? http://lsauto.com/products.asp i sent mine in to them. ill let people know how it turns out when it fires up.
 my car: http://forums.nicoclub.com/zerothread/252223 http://www.flickr.com/photos/11028609@N05/ -Dane
Kansei240sx
91 240sxHatch RB25DET, 86 AE86 Hatch 5SPD, 2008 Honda Ruckus 49cc gas saver!
Tulsa Ok
11-1-2004
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (lucky7) | 11:28 AM 7/13/2006 |
Tach Recalibration. 1. Pull Cluster 2. Remove Backin and Clear plastic cover for the gauge. 3. Take a sharpie and mark where the needle sits on the gauge face so when you're pulling the needles off you'll know where it sits so its not screwed up when you put them back on, you can also mark the spot it sits on. 4. Remove the gauge faces. 5. Where the tachometer face is... there is a variable resistor that you can stick a screwdriver in. 6. Ussually you turn it all the way to the left. 7. Once you've done that, do this entire process in reverse order. Now since all motors are a little different and so are the electrical outputs, you might have to pull it back out, an then turn it a litte more right and a little more right, to get it perfect. Just keep doing it untill you're satisfied or if you have an SAFC it makes it alot easier to calibrate. When using the sharpie on your gauge cluster, to get the stuff off, all you need it some axe body spray, or some red zone body spray. Apply it to some cloth and dab it onto the area that the sharpie has been applied to and it will either slowly or pretty much instantly come off.
If i left out anything or you're still confused quote and reply to this.
Previously powered by RB25DET, now moving up to an RB26DETT 91 S13 GT2/1 Track car under development. (R.H.C. Garage, Tulsa Oklahoma) SR/RB/VG nissan anything?! Swaps, wiring, electrical, fabrication etc. PM me if you need parts or wiring help! ASE MASTER CERTIFIED TECHNICIAN.
Dano
Super WizMod of OZ
'05 Nismo Frontier CC / '95 240sx base
Kansas City but miss Phoenix
10-29-2002
Awesome, good job Joe, maybe add a direct link to the thread with replacment part numbers and watnot.-Dan
 '05 EB NISMO CC 4x4 - HIDs, OE A/S Mats and Rain Guards, Garmin Dock, Soft Tonneau, etc '95 CG 240sx Base - Lots, Wrecked By Old People, Revival Has Begun  National Association of Storm Chasers And Spotters MEMBER -- AIM: s14sx2nr Love you Stace! Enjoy your wings!<3<3<3
Joe
single cam s14
Tucson, AZ
2-9-2003
| « Re: (240sx2nr95) | 7:46 PM 7/13/2006 |
im thinking about rewriting that thread completley, but not this weekend. have an event in phoenix lol
l0nestar
1993 250sx, 2004 Altezza, 1963 Impala SS
Indiana
3-10-2006
| « Re: (Kamin) | 8:03 AM 7/14/2006 |
I have been compiling alot of this same info. As well as other places. I will post any additional info if you would like Kamin.
If you did not build it, it is not yours.A job worth doing, is worth doing right!
Kansei240sx
Tulsa Ok
11-1-2004
| « Re: (l0nestar) | 10:16 PM 7/14/2006 |
Just a second thought... This should be stickied.
Dano
Super WizMod of OZ
10-29-2002
We'll work on it! Once this thread has the majority of the info we feel is needed we'll clean it up and all unrelated posts will probly be deleted. Joe, lemme know when you want to tackle that thread, i'll help get it organized. -Dan
lucky7
97 RB25 S14
Oakland township MI
5-3-2005
2 things i would like to add. remember, if you are starting out with a rolling chassis, you will need to find the Ka upper and lower harnesses. something i didnt realize.. im currently battling this harness issue. another thing, MAKE SURE YOUR RB COMES WITH A HARNESS! believe me, they are not easy to find. for some reason, my harness was missing. im still trying to get one. this will save you ALOT of frustration.
firstwizardshawn
1990 NISSAN 240SX
PAINTSVILLE KENTUCKY
6-20-2005
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 11:06 AM 10/24/2006 |
would love to see a pic of Custom throttle cable bracket so i will know what i am doing. thank you
gowron100
Nitro WV
11-13-2006
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 5:24 PM 11/13/2006 |
If you use the R32 crossmember instead of the mounts, how is the engine/transmission positoned? Does the engine sit too high requiring the hood bracing be cut? Is the shifter positioned correctly?I am thinking about doing this swap and have seen that using the crossmember is an option but I haven't seen if there are problems like with the RB25. Thanks.
The_Rising_240
1993 Nissan 240sx
Del Rio tx
8-29-2006
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 6:47 PM 11/15/2006 |
Oh i had a question for you when you are doing the rb26 swap do you have to get a rb25 oil pan or can you keep the rb26 one on???
ATpossible
1995 Nissan 240sx
Tucson AZ
10-24-2006
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (The_Rising_240) | 5:14 AM 11/18/2006 |
| Quote, originally posted by The_Rising_240 » | | Oh i had a question for you when you are doing the rb26 swap do you have to get a rb25 oil pan or can you keep the rb26 one on??? |
Its been done with a rb26 oil pan. i cant remeber how well it worked out. they took out the front diff. and covered up the holes. I've seen some other ones 2 i believe. Hope this helps. http://forums.nicoclub.com/zer...83716
kdkjrf
seattle wa
12-28-2006
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 12:57 AM 1/6/2007 |
RB20DET Belt part numbersI was wondering if you guys had the parts numbers for the RB20 instead of the 26 =\ my p/s is fritzing out on me, and I was wondering if anyone had the #'s for the rb20 thanks !!!
rb240det
1991 240sx Hatchback and 1994 300zx
MCBH Kaneohe Bay HI
4-19-2005
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (kdkjrf) | 9:13 PM 1/7/2007 |
| Quote, originally posted by kdkjrf » | | RB20DET Belt part numbers I was wondering if you guys had the parts numbers for the RB20 instead of the 26 =\ my p/s is fritzing out on me, and I was wondering if anyone had the #'s for the rb20 thanks !!! |
11950-04U00
PhillyDaKid-S13
1990 Nissan 240sx XE coupe, sold...(sniff)....1991 240sx fastback project, YEZZIR!!!
On a never ending quest to get mah epinefrinz PA
12-21-2006
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (firstwizardshawn) | 10:42 AM 1/13/2007 |
I'm also curious about the custom throttle bracket. Anybody have pics?
hab89
Nissan 240sx s13 Super Hicas
Conshohocken PA
1-8-2007
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (PhillyDaKid-S13) | 3:17 PM 1/13/2007 |
I NEED PICTURES OF THE RB20DET WIRING DIAGRAM?
soon2boost
Palm bay fl
1-16-2007
Im really considering doing the rb20 into my s13. Do i use the stock ka driveshaft or the rb?
Chaos the Xile
1974 Datsun 260Z
Latonia KY
2-9-2006
| « Re: (soon2boost) | 9:11 PM 1/17/2007 |
| Quote, originally posted by soon2boost » | | Im really considering doing the rb20 into my s13. Do i use the stock ka driveshaft or the rb? | you can use the stock KA but eventually will want to upgrade to a custom one-piece shaft.
 S1 RB25|REBUILD IN PROGRESS... COMPOUND TURBO KIT|KICKING AROUND A PROTOTYPE WTB: N1 Water Pump, Tomei Timing Belt AIM: chaosthexile E-Mail: chaoskid282@yahoo.com Myspace: www.myspace.com/chaosilvia
TriniGT
1-14-2006
| « Re: (Chaos the Xile) | 6:46 PM 1/30/2007 |
Just to add, for all RBs when changing the oil and water pumps, please while you're at it check to see what type of crank snout you have. RBs have an oil issue, for cranks with the shorter snout they will, at high RPMs, cause the oil pump gear to rupture because they do not fit flush in the gear. The fix for this is to get a JUN crank collar or something of the sort and have it machined onto the crank to have the crank fit the oil pump gear fully and hence no lsippage and a healthy engine. There are other oil issues because all oil is pumped to the head starving the sump of oil and spinning bearings, the fix for this is to install a small restrictor on the block on top of the other restrictor and block off the other passage. In the RB26 one of the restrictors is already blocked and the other will need reducing. To help oil flow quicker from the head to the sump you can remove the welsh plug from the back of the head and run a direct return to the sump. Please also try and get a baffled sump and oil cooler setup if you intend to do some drag runs and drifting.
skribblah
somewhere NC
2-23-2007
| « Re: (TriniGT) | 5:11 AM 2/23/2007 |
do you have a picture of the shorter vs. longer snout? thakns for the tip..
catatonicpinoy
1990 Nissan 240sx SE Hatchback.. 5spd. and stock^^
upland ca
3-14-2007
awesome info here^^ im looking into swapping out my sohc KA for an RB20det..
1st time nissan owner/drifter/240sx enthusiast...
...ex chevy and toyota enthusiast..
fanatic
Montreal QC
5-24-2007
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 9:55 PM 5/24/2007 |
Just a question, I remember the RB26DETT used to have some issues fitting into a 240 because of the twin turbo setup, but that was awhile ago, so would I still have to convert to right-hand drive or is that no longer an issue?
Joe
single cam s14
Tucson, AZ
2-9-2003
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (fanatic) | 1:42 AM 5/25/2007 |
you dont need to convert just need custom motor mounts and custom downpipes.
fanatic
Montreal QC
5-24-2007
| « Re: What is needed to swap a RB into a 240sx? *FAQ* (Kamin) | 12:52 PM 5/25/2007 |
Ah, alright. Thanks. I'm actually planning to swap for an RB26 once I have enough money. Student budget.
unknownracer
1990 nissan 240sx
channelview tx
6-6-2007
| « so is the rb25det wiring hard | 10:12 PM 6/6/2007 |
if i ask a question that has been answered, i'm new to this,i'm tring to put a rb25det into my 1990 240sx and i really need to find out as much as i need before i stick my foot in my mouth, you know what i mean, so if you have any pointers for me before i do this it would really help alot
unknownracer
1990 nissan 240sx
channelview tx
6-6-2007
| « Re:extend the wiring harness on the rb25 for 240sx (unknownracer) | 8:09 AM 6/7/2007 |
do you have to extend or will it match up?
thrashingdeath
89 Nissan 240sx se
Riverside CA
6-6-2007
| « Re: Re:extend the wiring harness on the rb25 for 240sx (unknownracer) | 1:06 PM 6/8/2007 |
Mc Kinney told me that using the stock mounts and R32 crossmember lets the engine to high and up, is this true?
| First 1 2 3 4 5 > Last |
