I would like to see where you got your info from Because most of it is wrong..
Roadkillracers wrote:B. 95-98 5 Lugs Hubs ARE interchangeable with 89-94 4 Lug Hubs.
No they are not the spindle on a s14 has a bigger shaft and will not intertchange with a s13 hub.
Roadkillracers wrote:C. (Front Only)You can find after market 4Lug (re-drilled) 300ZX 30mm rotors BUT they will not fit with the Stock SE Limited 15” Alloy rims. So why bother keeping the 4Lug at that point.
300zx brakes fit on one style se wheels. if your don't fit all you need to do is add a spacer. they brakes fit fine in a 15in wheel.
here is the link thats shows you the se wheels that fit.
http://www.nicoclub.com/articles.php?id=207414
Roadkillracers wrote:D. (Rear Only) mounting 300zx on the rear do not require 5 Lug conversion but you will need to swap out the backing plate from the 300zx as the E-brake is not part of the rear caliper as on the 240sx. You will also need E-brake cable extensions as the 240sx cables will not connect to the 300zx E-brake system.
This your right you dont need to go 5 lug you just need to have your rotor's re-drilled to 4-lug
Roadkillracers wrote:E. I have herd (Not that I know anyone personally who has done it) That th early 300zx None Turbo 28mm rotors and calipers with fit the stock SE Limited 15” Alloy rims.
If this is a z32 1991 and up 300zx the early model is a 26mm rotor.
Roadkillracers wrote:So If your going to 300zx brakes, might as well find some S14 5 lug hubs from the junk yard if your going through hasle since you need new rims any how.....
No you don't you can keep your 4-lug you just need to re-drill your rotors to 4-lug. or you can buy some on ebay that are already converted.
And you don't need new wheels you just need spacers if they dont fit.
link to 4 lug rotors..
http://cgi.ebay.com/ebaymotors...ZWDVW
