Versa / Tiida Wheel and tire size database.
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
JHR16DE
Car: 2010 Nissan Versa 1.6
240sx alloys look good on your V dude. Any mods required to install them?
lain
Car: 2007 Nissan Versa S
Clean_4th gen wrote:240sx alloys look good on your V dude. Any mods required to install them?
nope. they fit without any adjustments needed.
Jay.
Car: Versa
Katana RZ5 Racing Rims
215/45/17
+38
No rubbing or mods
Go sedans!
xdoug904x
Car: 2010 nissan versa
mmasica wrote:XXR 962 18x8.5 et35 with custom made centercaps
235/40/18 Front 245/40/18 Rear
Tanabe NF210 with 3/4 of a coil cut in the front. I need to cut more to even it out with the rear.
It will only rub with 4 people in the car.
This setup is pretty much perfectly flush. I didnt want to go with stretched tires unless the car is slammed.
its nice to finally see someone running aggressive wheel fitment on a versa. im about to order a set of xxr527 in 17x8.25 +25. what camber do you run right now?
dnastrandz
Car: 2006 Nissan Tiida
optik702 wrote:
18x 7.5springs on the way
Hey what is the make model of those wheels? Those are perfect on that ride man.
DentyCracker
Car: 2008 Nissan Tiida Latio Japanese Model
1498 cc HR15DE engine
SC11 Chassis
I'm thinking of getting some SpeedyWheels Fusion Black 15x6.5 (offset 38) and either 205/60R15 or 215/55R15 tyres. Would these work and would I need to change the tyre pressure from 33 PSI?
Tigermack
Car: '05 Mazda3
'03 Chevrolet Silverado 2500HD Duramax
'91 Toyota MR2 Turbo
Do you guys get a huge lost on MPG going to 17"? How about acceleration feel?
themadscientist
17x7.5 Focal F09s with 205/45ZR17 Hankooks check! :bigthumb:
blindsnyper
Car: 2007 versa
i really like those, good job.
Lububs
Car: 1.6 Visia+ Nissa Tiida(2007)
A-line 18" (225/40/18)
Rubs on full swing only
Custom drop.
Rims originally came in silver
Had them modified to Matt Black to go with ride theme
xtwoonamatchx
Sentra SE-R 17's
215/45-17 Nexen N5000's
Tanabe NF210's (1.5" drop)
+47 offset I believe (needed a 5mm spacer for them to fit over the calipers)
JunRaymond
Car: 2010 Nissan Versa SL
Rims: 16" OEM Nissan Versa SL rims
Tires: OEM Continental 195-55-16
Springs: Tanabe Sustec NF210
adrdxb
Car: Nissan Tiida/Versa SEDAN 2009
Dear Guys,
I am newbie in this forum, and i saw your forum about the Megan Lowering Springs. As of now, i have a original stacc of my Nissan Tiida and my tires is R15 Standard as of now, due to budget is concern i cannot change my tyres and rims to 17" so i prefer now, to lowered my Tiida.
If you could advise me if i am lowering my Tiida with megan springs does it look normal or too awkward with 15" rims.
Kindly advise and looking forward with you guys.
Best regards!
tarptruck
Car: Infiniti
I wanted to buy a wheel from an independent distributor, is it a wise idea? Or should I buy in an authorised nissan store. Kind of torn between the two.
Richie-CO
Car: Nissan Tiida Tekna HB 2012 (Mexican version)
MR18DE
4-wheel disc brakes
6 airbags
ABS + EBD
Excellent post!
Anyone can tell me if the XXR 502 17X7 with 225/45-17 will fit?
Thanks!
norcal618
Car: 2014 Nissan Versa S
2014 Versa S
18 x 7.5
No rubbing, Full turn radius.
Tevie
Car: 2011 Nissan Tiida
Will 215/45 on 18x8 offset 38 fit with no rubbing?
Return to “Versa Technical Discussions”
