VDC lights turn on and wont go off?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
mik3025
Car: 2008 Black on Black AWD EX35 and 2007 Black AWD Audi TTS Roadster
This happened a few time now,when driving my VDC lights turn on and wont go off until I turn off the ignition!
Thank you for your help
Obsidian EX
Car: EX 35 - Black Obsidian with graphite - Journey package
Have you had your brakes checked? I had the same issue, and it turns out that once there is sufficient wear and usage on your pads/rotors the VDC light comes on and stays on (this is especially true under accleration).
The one thing I notice about my EX is that it likes its brakes!
mik3025
Yes I think your correct.I`m feeling some vibration with the brakes and the light comes on, with harder acceleration.Can brake fluid level affect the VDC light?
Thanks for the info.
EX-KAT-35
Car: EX35, V70R, Civic
Click below for other user's experiences and the solution. :yesnod
It has already been discussed on here... :gotme
brake-indicator-comes-on-during-hard-ac ... 09016.html
Obsidian EX
mik3025 wrote:Yes I think your correct.I`m feeling some vibration with the brakes and the light comes on, with harder acceleration.Can brake fluid level affect the VDC light?
Seems to be the case. I was talking with my service advisor yesterday and he mentioned that my brakes are nearing the end, and will most likely be due for replacement at the next service. I brought up the point about the VDC light and he said that if I was out of town and away from the dealer, that I could top up the brake fluid and this should stop the VDC light from coming on (and staying on).
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
