Hello everyone and happy 2012.
Glad to see a lot of people are still active on here.
I am also a victim of the rear brake "phenomenon".
Dashboard lit up like a Christmas tree.
Started gradually around 32k miles Now @ 36k.
Dealer fixed the problem but mentioned that I needed REAR brakes ASAP and that I had 1-2 mm of brake pad left.
They also fixed the front end shimmy problem I had in some form since 2009.
I reported it to them then and they wanted to give me several hundreds of $$$ of front brake job stuff.
Funny now there is a TSB I got the front brake pads and rotors done under warranty at no additional cost to me.
Dealer wanted $431 or $481 to install rear rotors and pads.
My friend said I should pass bcs he just checked my brakes and there was waaaay more then 1-2mm of pad left back there.
could the dealer be trying to scare a girl into spending money??? NOOOO!!!
I started back in 2010 saving for a higher quality BBK my friend found me since there was quite a bit of front pad left.
I am currently going a road less travelled with my brakes.
No more spongy pedal here.
In other news I finally wore out my 19s and last weekend I got the "proper" sized tires on there with the correct 703mm rolling diameter front and rear with my staggered setup. 12k + miles and rolling strong on the staggered setup no hicups here.
New tires are 245/45 and 275/40 Yokohama Advan S.4 A/S
