Luke »
Thu Jun 02, 2005 9:53 am
Whoa!! change your oil NOW. If you added Seafoam, that thins your oil to nothing. People add it to their engine oil for cleaning purposes but you should NOT drive it more than a mile or two like that. No wonder that oil looks like crap.
Has your oil light come on at all yet? (Low oil pressure)
Also, since you sound a little new at this, i want to offer another bit of important advice. When you put the bolts back in for the valve cover, there is a certain sequence you need to tighten them in. Also, do NOT tighten the bolts more than hand tight (only 5-10 ft/lbs of torque needed!) If you tighten too much, they will strip and you will have bigger problems. You'll have to end up retapping the holes!
It is ok to reuse the rubber valve cover gasket as long as it isn't dry-rotted and cracking.
Modified by Luke at 4:05 PM 6/2/2005
