Well I've added a fmic and I need help with some vacum just to double check if i got everything right.
This is for reference i found it at
zerothread?id=305170.
Well i bought the car already swapped so it look like i'm missing the EAI control valve, the EAI control solenoid and the boost pressure solenoid because i did not have any of those lines running like that.
Now lets look at the first pic :roll: Now is this right if i have the line from the wastegate go to the line beside throttle body. Is this how you hook up a BOV?
Is it alright if i plug this one up, my friends 180's is plugged up.
Now i think this is the reciculatory system i dont think i'll keep it because it will just add more vacum line headaches. Can i put my bov at this spot? If not what's the best way to cap it off?
Now for the finale!Since i won't be using the recirculation valve i can just cap that hole off, what's the easiest way?
Thanks for your patience,!!Alex
