vaccum problems
midnight180sx
Car: 1989 240sx hatchback
Where does the vaccum for the wastegate run to on a s14 sr20 with a greedy fmic kit.
S13FASTBACKSR
Car: '92 Fastback SR powered
you have to have a nipple welded onto your hotpipe
midnight180sx
I cant run it some where off the throttle body.
S13FASTBACKSR
has to be a pressure source not a vaccuum source..I take that back you can run it off the throttle body and it does work even though thats vaccuum but you should run it off the hotpipe because thats a pressure source ..the close to the actuator the better (the shorter the vac line the better)
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
running a stock wastegate actuator on vacuum usually causes them to fail
S13FASTBACKSR
exactly..thats why you should take the time to have a nipple welded on my friend.
midnight180sx
Thanks for the help but where do I get a aluminum vaccum nipple from
IanS
check hardware stores and such, and if you cant fine one, call up Jeff at heavy throttle, Im sure he can help you out.
