Your friend is correct. All (or very nearly all) modern engines (and indeed most engines made in the last 15 years) including the new Q's VK45 will compensate for lower-octane fuels. That's why you usually see "RECOMMENDED" instead of "REQUIRED" when referring to use of top-grade fuel on newer cars.luvmy94q wrote:An engineer friend of mine who drives a newer Q said he puts regular gas in and the computer adjusted -- sounds like B.S. to me but w/
Yes. Quite true. It may be a coincidence, but when I first got my Q, (I was dumb as hell boy.) I spent the first three months putting in Regular 87 because I was of the "All gas is the same."qship96 wrote:Premium unleaded only for a properly operating q45
HOWEVER, for many {most?} q45 owners, who are showing a knock sensor code stored in memory- might be perfectly fine to use regular grade unleaded, as your ECU is operating in safe mode with the timing already retarded - using premium may just be flushing dollars down the drain, as your engine is not operating with timing map advanced to need or benefit from it.
I have some sort of weird personality quirk that stops me from being at the gas station and not filling up.seldomseen wrote:If I'm down to a half tank of gas I will fill up tank up using Mid-Grade, but when I'm down to 1/4 tank or less I just fill it up with Premium. Never had a problem doing this yet. I won't touch the Regular unleaded though...
I'm sure Haitian King can vouche for me, but I was in New Jersey back in 2002 and all the gas stations had 94 octane. I thought that was awesome.qship96 wrote:Up until just a couple of years ago, I used only 94 octane Sunoco in the Q-for some reason, they stopped selling it in the Balt/Wash area- does anyone here have it in their area?
Quite simply, the rest of the world primarily runs on diesel. Trucks, cars, power plants, boats, tractors, etc.Q45tech wrote:Why does diesel cost more because it can produce 139-140,000 BTU vs gasoline 125>114>110.000 BTU per gallon.
jimbyjimb wrote:Probably the best thing that a human could do for the world at this point is to buy a diesel and brew your own biodiesel. Big savings for the wallet and for the atmosphere. I saw an episode of trucks where they actually were able to make more HP and TQ on their own special brew of biodiesel that they estimated cost them 77 cents a gallon. It took one-weeks brew time approximately for 25 gallons. When I worked for Swift in 2005 and diesel prices were around the area of 2.80 to 3.00 a gallon Swift sold diesel, at a profit, to owner/operators at 1.25 a gallon. People think buying hybrids save the world. Diesel engines are amazing. What with diesel technology catching up to that of gasoline. And they last so much longer. Time for an International V-8 swap into the Q? That'd be pretty darn cool.
Forgot to add in to check out the world's coolest super-sports car. The Audi R8 concept is powered by a Diesel engine. Check out Gale Banks' endeavors as well.
Modified by jimbyjimb at 6:18 PM 4/13/2008
Are there "quiet" diesel engines? I'd hate for my Q to sound like one of those big clattering Dodge Cummins Diesel pickups.
Modified by jimbyjimb at 6:20 PM 4/13/2008
I get 92 in my Q all the time.Kiven422 wrote:You guys have all this talk but the Q was made in 1990. Today the only "premium" available is a 91 octane rating, on top of that 10% of its ETHANOL.
My smog guy was telling me I could probably get away with 89 Octane (midgrade/unleaded plus). I've never put anything but premium, but with prices as high as $4.19 in my area (how high is it gonna get in the summer?) I think I just might give it a try or retire the 94Q its a damn guzzler. The 93 ain't so bad.
I'm looking at the new Civic SI 4 door or a 03/04 Infinti M45 --- those are bad, but it dont give you that japanese muscle car feel like the Q.
Ummmm, the 03/04 M45 has more muscle than your Q, plus it's a better car.Kiven422 wrote:or a 03/04 Infinti M45 --- those are bad, but it dont give you that japanese muscle car feel like the Q.
Faster,yes.....a better car? No, not even close in engineering and build quality. Almost flimsy compared to the overbuilt g50......and you have to stare at that butt ugly mini-van looking dash every mile you drive it.NightRiderQ45 wrote:
Only if you are a captive of The People's Republic of Kalifornia.!Kiven422 wrote:You guys have all this talk but the Q was made in 1990. Today the only "premium" available is a 91 octane rating, on top of that 10% of its ETHANOL..
