thats my number one concern. also, with spacers, when you push the wheel in, you might not get the full surface area like you would with hubcentric spacers. i mean, when you think about it, these spacers can be very crucial to an accident waiting to happen.the_momo wrote:1. less thread engagement
Well there you go, you know one person is doing it.eds13 wrote:i had to use 2mm washers for my wheels to clear the coilovers. i wouldnt use anymore than 2mm. and make sure you measure each one to sure that there all 2mm.
No, your pretty much right. In here, its pretty much a mix of 60% idiot ricers, 30% who actually know something, and the rest are asking questions or typing things they "heard" or "think" they know about. All the other NICO forums arent as bad...rdx4me wrote:Are there any real "Subject-matter-experts" out there or is this all just a conglomeration of wanna-be racers????
[email protected]. Ill take 5mm spacers cause I'm to broke.benemorius wrote: If you are considering this because you can't afford real spacers, give me your damn paypal address.
I don't wanna be a racer, but I did just pass Physics with a C. I learned about something called shearing, and shear strength. Maybe you should read up on it.rdx4me wrote:There are so many articles on this site concerning the use of spacers (sandwich or bolt-on) that those of us new to NICO don't know what to believe...is this all just a conglomeration of wanna-be racers????
Stay away from washers....retarded idea...you get the christmas slap from me~4N~ wrote:Good size & offset wheels > spacers.
Im running 25mm spacers , hub and wheel centric though. I still had to follow the proper break in procedure, or else you might break a stud.
You have to check the torque for lug nuts several times once you install them for some period of time. Because of heat, slight movement...etc. I think that's what he meant.Atown 240 wrote:Proper break in for spacers?
