s13EastTN »
https://forums.nicoclub.com/s13easttn-u15057.html
Sun Jul 18, 2004 3:14 pm
Ah I got it, I was off a tooth with the dist, and it sorta started, so I kept turning the ignition (IE flooding engine). So i adjusted the dist back and forth thinking it was timing, didn't get anywhere so I gave up since my girly friend was here. This morning, went to start her up and and she gets up there, runs sorta so I give it more gas to try and get stuff worked out. It eventually evens out (read: got all the gas out) and now idles pretty good. Doesn't run the best, but I think that can be worked out with a timing gun faily easily.
Btw your engine has to run, not run great but run for a timing gun to work.
