DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Dec 30, 2002 10:11 am
There isn't a lot of overlap, but there's a little. Filling out the paperwork, getting the car on the lift, and removing the wheels. No direct overlap between rebuilding the shocks and replacing the tension rod or sway bar bushings that I can think of. There is enough overlap to justify knocking off a little IMO, but I'm guessing you will have to convince them of it. The labor rate is fixed, so always negotiate in book time. Ask them the book time for each thing you want done, then ask them how much time they'll take off to do all at once. Be ready to rattle off those three taskes and any others you can think of if they're less than eager to work with you. If this is a shop you will be bringing your car to a lot, it never hurts to grease the rails. $20 to the right people (service writer and tech) on a couple visits, and they WILL remember you.My friend is getting free labor in exchange for a nice rolling tool cabinet he surplussed from work, but it would otherwise have cost about $150 in labor for 2 front shocks (2 hrs x $75/hr). Parts are under $100 for the rubber, plus $160 for the struts. That's roughly what I paid for my '90 Q, then add about $100 per upper link. I don't remember what the tension rods cost, maybe $75 each. Sway bar bushings are maybe $5 each. I haven't yet looked into the other things, like wheel bearings ($200+ each!), kingpins and bearings, balljoints, etc. Still a couple more items above them on my todo list.
