BamaCoupe wrote: Maybe in ten years or so when everyone's warranty is up or when our car will be in the hands of the third or fourth owner.....
Alright cool okay so pretty much I'm hearing these CVTs suck so is it possible to swap trans to a gear? I mean I know there's places you can grasp used ones with 50k but how tough would it be? I mean I know you gotta swap computers and all but I'm thinking swap that then throw a G or Z engine in there down the road and that could be pretty bad..BamaCoupe wrote: Sorry for the rant; I'm guilty too for not experimenting, but I'm not mechanically inclined enough to go taking my engine apart. Maybe in ten years or so when everyone's warranty is up or when our car will be in the hands of the third or fourth owner.....
At the moment I'm not still got it under warranty so gonna stick with the CVT til it's up but I got a uncle who owns a car lot and has hook ups on trans/engines so I'm not worried about the $$$ lol but if this dude had that much trouble alone idk if its worth it lolel_blacky06 wrote:I doubt you're serious as to switching out transmissions and engine but here's a thread of the 3.5 cvt to a 6mt swap
altima-cvt-to-manual-swap-the-final-res ... 71472.html
Alright man that truly isn't worth my time because I travel way to much for work in this thing anyways. Ok so should I still throw an exhaust/intake on it so it at least sounds alright and then save up to buy a 3.5 6MT to turbo and everything? I got connections on finding one since my uncles in the used car business that wouldn't be a problem. Might as well run this to the ground while I got it but since you said the CVTs suck even more on the 2.5s would a intake/exhaust be to much on it? Or no?CoupeVQ35CVT wrote:I understand you're looking to update your 2.5 for more power.
Forget all the transmission and engine swap ideas you might have had (sadly). The cost has proven to be prohibitive, mostly due to 2 reasons:
Bolt-ons for the 2.5 and 3.5 CVT Coupes are fine, it's just when you start to get on the pedal more and more with significant upgrades that start to show problems. Bad luck aside, I don't think most of us have had issues with aftermarket exhaust, intake etc. Those with problems either had them bone stock from the get go or just randomly down the line, or very obviously after turbo or something crazy like that. My 3.5's will hit 100,000 miles as of the next couple weeks and I've been running an exhaust and later on y-pipe from 1500 miles on the odometer (so 98,500 miles!) and I drive a little spiritedly every now and then but not all the time, including using manual mode 50% of the time with engine braking. Now that kinda stuff should explode the CVT but I'm one of the few lucky ones or perhaps that's how it is supposed to last.YoungCoupe wrote:No you should definitely throw on an intake and exhaust. Someone correct me if I'm mistaken but bolt ons for the most part shouldn't affect your transmission.
Sweet so exhaust intake bully dog GT? Anything else I should throw in there?AlexN09 wrote:No it would totally be fine.
Really? Ok do you by any chance have the forum link to that dude so I can find out the full details on what he did? That would be awesome!LIPrincess wrote:See the trick is, know the limits of the car. The 2.5s can handle turbo, but u can't boost it more than 5lbs. With that being said, u can get up to 350-375whp, and in the coupe, that's the ultimate sleeper. Done my research, plus we have a member on here who did it and his car still runs fine off the boost build.
I don't think you could get a 2.5 up to 350whp, especially not with a CVT. I would estimate somewhere around the number 250. That being said, I would not be upset if you proved me wrongLIPrincess wrote:See the trick is, know the limits of the car. The 2.5s can handle turbo, but u can't boost it more than 5lbs. With that being said, u can get up to 350-375whp, and in the coupe, that's the ultimate sleeper. Done my research, plus we have a member on here who did it and his car still runs fine off the boost build.
This statement is completely and utterly false.LIPrincess wrote:See the trick is, know the limits of the car. The 2.5s can handle turbo, but u can't boost it more than 5lbs. With that being said, u can get up to 350-375whp.
lmaoLIPrincess wrote:See the trick is, know the limits of the car. The 2.5s can handle turbo, but u can't boost it more than 5lbs. With that being said, u can get up to 350-375whp, and in the coupe, that's the ultimate sleeper. Done my research, plus we have a member on here who did it and his car still runs fine off the boost build.
