Upgrading from 2006 Bumper/Headlights to 08'
Europeenne
Car: 2006 M45 Sport w/ Aero Kit, Journey + Tech Package
long story short, was in a wreck and bumper, headlights, hood need replacing, and if i'm coming out of pocket, might as well do something new and interesting right?
wreck thread if anyone cares: worst-day-of-my-life-possible-damage-es ... 80980.html
just need some help with a few questions please guys
* is there a difference between the 08 sport bumper and 08 non-sport bumper (Front)?
* could swapping to 08 bumper instead of rebuying an 06 bumper be that much more expensive? what do i need to take into account, new grille and fog lights for 08 bumper?
* is there a difference between 06 sport headlights and 08 sport headlights? keep seeing something about a gap when making the swap?
* when looking at the swap threads of the past on here, seems like no 06's who have the aero kit made the swap? is a 06' bumper with the aero kit lip held in higher regards then a lip-less 08 bumper? does my 06 aero kit lip go to waste if i make the swap or can i put it to use on an 08 bumper (retarded question)?
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
ya man...it sucks to hear what happened...I recently got rear ended...it's the inconvenience of not having your ride for awhile that is worse :mad: BUT, you're alive and cars can be fixed :biggrin:
I've done the 08 sport bumper conversion, so I hope I can help a little:
* is there a difference between the 08 sport bumper and 08 non-sport bumper (Front)? YES - the 08 sport bumper is more aggressive while the non-sport is subtle in styling...I have the sport version, while another forum member - DEANM45 - recently swapped to the 08 non-sport...here's a link to an Infiniti front bumper guide, just look for the year of your choice:
http://www.oebumpers.com/inventoryresul ... e=Infiniti
* could swapping to 08 bumper instead of rebuying an 06 bumper be that much more expensive? what do i need to take into account, new grille and fog lights for 08 bumper? yes/no, you can always get a used 08 front bumper as well. you will need an 08 front grille, 08 fender liners, 08 fog light housing...if your actual fog lights are not damaged, you can use those in the 08 bumper. I picked up 08 Sentra fog lights as replacements when I had a cracked fog light...same size and a lot cheaper...found on ebay
* is there a difference between 06 sport headlights and 08 sport headlights? keep seeing something about a gap when making the swap? the headlights are the same size - I believe - the gap that occurs is from the bumper itself, meaning if the bumper is not OE, then fitment issues may occur. Also it depends on the body shop installing the bumper...some shops are more skilled than others so making a sure fit may be dependent on the skill/expertise...
* when looking at the swap threads of the past on here, seems like no 06's who have the aero kit made the swap? is a 06' bumper with the aero kit lip held in higher regards then a lip-less 08 bumper? does my 06 aero kit lip go to waste if i make the swap or can i put it to use on an 08 bumper (retarded question)? is your front lip still in good condition?? can't really tell from the pix...if not, then you'll need to get an aftermarket front lip if you stick with the 06 bumper - Infiniti does not make aero kits any longer - the company Serona makes aero kit style as a replacement. Not sure if an 06 aero kit front lip will fit an 08 front bumper w/out any modifications from the body shop
Europeenne
CPJ LB wrote:ya man...it sucks to hear what happened...I recently got rear ended...it's the inconvenience of not having your ride for awhile that is worse :mad: BUT, you're alive and cars can be fixed :biggrin:
you're f*** awesome bro thanks, saw a lot of your posts in older bumper swap threads when browsing
1st time i'm hearing about the fender liners or maybe i'm just confused
2008 Infiniti M45 Sport Bumper - $275 (From a nearby shop - very good deal, the actual bumper usually goes for $330+)
Right Fog Light Lens [Part Number# 62256-EJ90C] - $45.51 (Quoted $89.20 from dealership)
Left Fog Light Lens [Part Number# 62257-EJ90C] - $47.73 (Quoted $93.54 from dealership)
2008 Infiniti M45 Grille [Part Number# 62310-EJ90B] - $235.98 (Quoted $332.50 from dealership)
2008 Infiniti M45 BOTTOM Grille [Part Number# 62254-EJ90A] - $93.22 (Quoted $156.62 from dealership)
2008 Grille Emblem - W/ Sport Package - $32.85
is there any best place to find the sport headlights or is it just luck?
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
it's all good brotha...glad to help.
the 08 fender liners (the piece that fit in each of the wheel wells - like splash guards that surround the front tires so crap does not go into the engine bay from the wheel wells) in the 06 they are shorter so when doing the 08 front bumper swap, you will see a gap of about 1-2 inches on the inside of the wheel well...I got mine about 2 years ago... at Infiniti parts usa:
1 of : Protector-Front Fend
(63844-EJ90A)
(63845-EJ90A)
The sport headlights are luck of the draw when searching used...maybe junk yards is a good look...
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
I found some pix from an old thread of mine...
BEFORE: with stock grille painted and billet grill powder coated
stock bumper w/billet grille powder coated
AFTER: the 08 bumper looks more aggressive, yet subtle and high-end
passenger side
middle & grille
driver side light
pass. side light
lower mesh grille
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
good info. in this thread I will start my swap around Christmas when I have some time off from the job. next year NOPI show I hope to have my car in it as there were no M35s in this years show.
DeanM45
Car: 2006 Infiniti M45 Sport 1 or 2 mods
Yep, did the conversion to the non-sport 08 bumper on my 06 sport.
For reference
Sport (CBJLB's):
Non-sport (mine):
Build thread on mine: new-headlight-idea-grill-mod-and-ink-pens-t578064.html
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
pictures of an 06/07 M with the aero skirts and rear and the 08+ sport bumper
I personally don't like the look of the two together as I think the lines don't flow well together, but now you can see it for yourself and make your own decision. :dblthumb:
Europeenne
all your cars look super hnnnngggggg
now i'm excited as s***
front end accident = blessing in disguise
nanative
Car: 06 Infinti M35 X Ivory Pearl
The white M35 in your pic above has the 5 spokes that split at the end. Does anyone know who makes these rims?
Ilya
Those are stock 20" M56s wheels.
