Is it possible that the manufacturer may have improved the plastic compositions in the replacement injectors over the years since it should have been a known manufacturing defect by now?
Texasoil indicated he installed the 96 injectors in his 92 using steel washers in the intake manifolds.
zerothread?id=214756
Quote "Actually, deleted the OEM hard black spacers under fuel rail bolt pads, shimmed to(lower) level height with steel washers so all square up with injectors fully seated. Injector tip sits +/- 1'8" deeper into intake runner."
The 96 version are the top feed style I understand, and may be similar to the 97-01 versions? I haven't heard of any problems with the '97-01 injectors. However, wouldn't you need to use some kind of rubber gasket to install the fuel rail into the intake manifold in order to get a tight enough seal around the individual injectors?
