i would get most your stuff from phase2. they are our sponsors and you get a discount on instock part.s
WHOA WHOA WHAO hold up here
GT2871 turbo, - get it from Phase 2 72# injectors - get 550cc or 740cc deatsch werk ones also a sponsor, JGY fuel rail- use your stock fuel railJGY top mount turbo manifold Use the stock bottom mount manifold. or get an tubular bottem mount. top mount will hurt your spool up.any other necessary piping- greddy LS intercooler.-nismo fpr- good choice here get and inline FP gauge.-factory time chain kit - Why? nothing wrong with the stock one. it is a chain not a belt.-greddy rocker arm stoppers- good choice here but not a necessity -factory water pump - could be an good idea depend how yours is working now.-cometic head gasket- get an apexi headgasket phase 2-arp head studs - good choice - phase 2-greddy mbc - HUH get a HKS adjustably actuator -z32 maf - NICO FS section-enthalpy tune - pick up a used one its alot cheaper then you dotn have the down time and you can sell your old ECU
Looking to run 16-18 lbs. - me too. check out my build and you can pretty much copy it.
zerothread?id=281805 stock bottem end will be fine. ight? i am out
