KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sun Nov 26, 2006 10:24 am
My current setup:
Dual chip daughterboard with on-board switching and multiple map storage. This is for the OBD I DOHC model only.
Pros:
Fully adjustable in terms of total engine management (timing, fueling, cold-start enrichment, throttle tip-in, etc.).Easily installed in the factory ECU.No need for any piggyback system.
Cons:
Highly involved and not for the novice tuner.Currently, no map-trace function available.HybridKA is VERY busy and somewhat out of pocket these days (though that will settle down probably about Spring of this coming year).Not certain if these boards are ready for release to the public yet.Requires dual chips with identical programming, making it expensive to tune on the fly via emulator (requires twin emulators @ over $200 each).NOTE: These can be tuned without the emulators, but you'll have to try a tune, check the data, reconfigure, burn to chips, try again.
This board came from hybridKA as a beta-testing venture. Basically, he had only a handful of boards and was saving them for unique projects. Mine just happened to pique his interest, so I got to purchase a board from him.
Here's how it works.
The board can store a total of four individual map sets. One set is a complete tune, having cold start function, injector parameters, VQ parameters, fueling and timing tables, rev limit, etc. So, the board holds four of these.
The board itself hase two dip switches. Depending on the dip switch settings, the associated map will be used.
Example:
Switch 1 "ON", switch 2 "OFF" = Map 1.Switch 1 "OFF", switch 2 "OFF" = Map 2.Switch 1 "ON", switch 2 "ON" = Map 3.Switch 1 "OFF", switch 2 "ON" = Map 4.
Now, either of the two switches can be setup to operate via remote mount switch. By operating one of the switches remotely, I can toggle between two maps.
Currently, I have the remote switch attached to the clutch pedal assembly so that when the clutch is depressed more than about 10-12mm, the switch circuit is closed and an alternate map is activated. When the clutch pedal is released, the switch circuit goes open again, reverting back to the original map.
The two maps are set up as follows:
Map 1 (pedal released):
Base tune, rev limit set to 6850rpm
Map 2 (pedal depressed):
Fuel enrichment, timing retarded heavily, rev limit set to 4000rpm.
The purpose of the two maps is two fold.
1. I have a 2-step launch control. I can hold in the clutch, push the accelerator all the way down and the engine will bounce around 4000rpm, and build a small amount of boost sitting still.
2. I have a flat-shift feature. I don't have to lift the accelerator between gears because of the lower limit. This helps reduce turbo lag significantly between gears.
The remaining two slots can be used for other options, such as a race-gas map, valet map (limit revs to 3000rpm so they can't boost), or even an anti-theft map (set values so that the car CAN NOT run, even if hotwired).
