maxnix wrote:I thought I heard some untoward mechanical noises, so I was wondering.
The car has over 230k miles on it. The Level Ten rebuild has almost 120k miles on it. There is still a lot of stuff that needs to be sorted out. I just haven't had the time nor resources to do it.
maxnix wrote:Turbos at altitude have to be king. For a 4.08, 18 -20 sounds right as you should see about a 15% decrease in MPG, so the turbo must have been used infrequently as you maintained.
When you are cruising at 70 mph, the turbo is still spinning but not fast enough to create positive pressure so the fuel consumption is not affected.
maxnix wrote:Remember the old days when hot rodders would louver hoods, much like the old XKE? I think the problem with the G50 hood may be designed to buckle about where you placed yours and where they need to be. It might make the hood too weak to do so. I also wondered about fender vents high behind the front wheels?
The vents are riveted over the metal skin of the hood. The frame underneath is still intact so there shouldn't be any concerns over structural integrity of the hood in an accident. As far fender vents, I haven't found a spot for them inside the engine compartment.
