elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Jun 24, 2003 4:20 pm
Use only premium..... You will get better gas mileage, your car will perform better (a LOT better), and its just better......
Look at it this way.... Most places only charge 10c more for premium over regular (at least in IN), so if you fill up 20 gallons, it only saves you $2 a fill up, and say you fill up once a week, thats $8 a month, $96/yr...... pretty insignificant if you ask me, especially to keep your car healthy and happy!
The engine can only compesate for so much pinging..... what it does to do that is it retards the timing (essentially lowering the compression ratio), and that means MUCH lower performance, and lower gas mileage...... You may even get enough better gas mileage over premium/vs unleaded to offset the costs (that may be pretty drastic), or at least close......
