in my '97 J30 with over 100K miles. I maintain the car meticulously and use synthetic fluids throughout. I had never...and I mean never, run anything but premium for the longest time in the J30. However, after reading an article in USA Today recently, where the consensus of a number of auto mfgrs engineers saying you might lose 5% power but not harm your engine,(I was going to provide the link, but you now have to pay for any article over 14 days old) and with premium over 2 bucks a gallon, I have been running regular.
I have seen no difference in performance, possibly a slight drop at WOT, but I'm not even sure about that. Yes, higher compression engines are supposed to benefit from the slower burn of higher octane gas, but when the head engineer for Daimler-Benz states in the article, that he always runs regular in his Benz, with no ill effect, then I decided to try it, and I wish I had the 4 bucks a tank extra that I have spent for years on premium.
The knock sensors on modern cars are so sensitive, that they retard the timing immediately, usually before you even hear anything, and a motor is running at it's most efficient when it is right on the "edge" of pinging, just a hair, under load.
It is also considered a mark of "luxury" cars that they require premium fuel. If I had a turbo car, or a very high compression motor, I would probably buy premium, or mid-grade at the least, but the J30 has been running dandy on regular, and I plan to keep on using it.
I am sure I will get flamed for this, but most on the board that insist you run premium, or suffer dire consequences, are the same ones that change their synthetic oil at 2,500 miles...what a waste of money and resources...it's your cash, do what you will.
Oh, and lastly, I check my mileage at every fill-up...same as I got with premium 18 to 22 MPG.
http://www.caranddriver.com/ar...=3604
