hstylez »
https://forums.nicoclub.com/hstylez-u38933.html
Mon Apr 30, 2007 5:26 pm
Let me start with the details. 93’ 240 with an s13 redtop swap. A few months ago I had this thing fired up just fine only time find a leaky turbo gasket. Took all that noise apart and reassembled and am now having some issues with starting/running.
Here is what is happening currently:It will crank-fire-crank-fire-fire-crank-crank….and will not stay running on its own. One of the things I noticed when I turned the key on is that the fuel pump would turn on, and stay on until I turned the key off. I thought the fuel pump was only to run for a couple of seconds with the key turned on, and shut off automatically if the engine was not being cranked yet. Interestingly enough, a few months ago when I had it running, the fuel pump shut off on it’s own before a start.
So after I tried to start the car several times, I could smell unburnt fuel near the exhaust pipe. I figured the engine was flooding itself (somehow, with the fuel pump not shutting off at key “on”, and the fuel smell), and so I disconnected the fuel pump fuse, cranked the engine over a couple times, and then left the car for a bit. When I came back, I put the fuel pump fuse back in, and when I tried starting the car again, I went immediately from key “off” to “crank”, not giving the fuel pump time to run without the engine cranking. The car started up right away, and ran fine for a couple of seconds. It then started to run all stumbly like, and wouldn’t react at all to the throttle. I tried tapping on the fuel pressure regulator, and the injectors while it stumbled, but the tapping didn’t seem to cure the irregular idle.
When I say stumble, I mean the engine sounded like it was running on 2 cylinders, and violently shook about the soft motor mounts. While it ran rough, the engine would barely react to throttle changes—I could open half throttle, and the engine would hardly rev. I noticed also that the black smoke was puffing out of the exhaust while the engine stumbled. I attempted to start the car several times after this, and only got it to rough idle.
Things I would like to know are:-Doesn’t the fuel pump have some sort of timing mechanism when the key is turned on? Or does it pump until a desired fuel pressure? Or is it supposed to always run when the key is on?-Even if the pump did run nonstop, the fuel pressure regulator should keep the pressure at the injectors constant, and not create an over-fueling situation…would a bad FPR force the injectors to leak?-Could the injector(s) be stuck open?-What is a good way to test the injectors to see if they are leaky?
Any other suggestions to what might be going on would be great. Anyone else have this problem? Thanks for reading!
