Unique intercooler location
dontuhatepants
Car: 93 s13 coupe sr20 etc., 95turboeclipse, 08 CRV
Ok, I don't know if this is actually unique or not but I wanted to post some pictures of my intercooler location and see what people's opinions are. Obviously these are all works in progress but I'll update when it's done.
I'm doing a silvia conversion and had everything apart and decided to see if I could put the intercooler a little more stealth so I didn't have to f up my bumper.
As you can see, it's going to be a ton less piping and I hope better response. I'm working on it in a few minutes and will update as I go.
Thanks for lookin!
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
next to the rad? too much heat?
ImportBastard
Car: 1989 coupe
to cheap to buy piping? and your gonna defeat the purpose of the intercooler by placing it next to the RAD...
phreezer
Car: 1990 s13 240sx Hatchback ca18det
I'd try a smaller IC and piping if I were doing track racing or cone dodging events, but atm I have a monster sized IC and piping on a ca18det causing some noticeable lag.
I'm only a few IQ points from mounting an intercooler in the trunk so I don't know how the radiator heat would affect it. Should be fine if your moving forward blowing air across it and not sitting stopped for a long time. Leave the fans on and get a vented hood.
BHayes_S13Coupe
Car: 1990 Nissan 240SX (Coupe)
been done, that setup is mostly called a "midmount" setup.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
I would run 2 sets of fans, one set pushing, and one set pulling
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
phreezer wrote:.....but atm I have a monster sized IC and piping on a ca18det.....
a$$ to mouth??
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
snwbrdr435 wrote:
a$$ to mouth??
Yikes.
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
r34 gtr wrote:
Yikes.
adrianfromthecastle
Car: 1992 Nissan 240sx
there are advantages of having the ic in that location. Shorter ic piping = better response. Also, if its for a DD, cops won't be able to see it...
MastaYu
Car: 92 Nissan 240SX SE HB
interesting
ImportBastard
Car: 1989 coupe
interesting... hmm... why not just go topmount? shortest ic pipes...
nissanman04
Car: '90 240SX, '95 Subaru Legacy
heat
soak.
MastaYu
what about a V-mount?
Kalypso
van gitten jr's s14 did it also.
in case he can tapped a wall they could just replace the bumper.
MastaYu
s
Kalypso123 wrote:van gitten jr's s14 did it also.
So sick
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
neat idea, but i like the good ole fmic look....or the V-Mount
tramp_drift240
Car: 1992 240sx SE Coupe
i kinda like that. i dont want to have to cut up my pig bumper for a FMIC.
i can understand how the heatsoak could be a big issue, but how bad is it really?
Kalypso
^ Thats a good question, front mounts win out in terms of efficiency. see the right most bar on this graph.
here's the article http://autospeed.com/cms/artic...t+Two
you can also coat an intercooler with http://www.swaintech.com/store.asp?pid=10968 so that is dissipates heat faster
swain tech sells it. your front mount will start to look like the one in the front.
Modified by Kalypso123 at 10:30 PM 8/3/2008
Red Devil
Car: 1990 240SX w/t SR20
2008 Nissan Versa SL
It looks like VGjr.'s setup is a liquid to air setup. But back to the subject, wouldnt you get almost no airflow to the rad with that setup? At least with V-mount or FMIC you have some airflow. And heat sock would be a big issue. I think their are better ways to reduce lag than that.
Kalypso
I guess we would have to see it with the bumper on.
he could make ducting out of sheet metal that funnels the air into his intercooler. and with fans he should be set.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I ran my old IC like that as well. You don't run into that much heatsoak with the radiator. The only times I ever encountered any overheating issues was due to my fan not working at idle (had the ground cable come loose of it's crimp connector)
In fact, I'm currently running a Spearco IC tucked up under the core support. And guess what? Still no heatsoaking issues.
Also, I'll take my shorter piping any day of the week.
ImportBastard wrote:to cheap to buy piping? and your gonna defeat the purpose of the intercooler by placing it next to the RAD...
Explain that please. Air goes over the intercooler first. The radiator shouldn't be blowing its air across the IC, or you're doing it wrong
tramp_drift240
ABOUT THAT GRAPH.
are you sure thats not just comparing the stock size intercoolers to aftermarket intercoolers, in terms of the materials used and the size of them?
i dont think that has anything to do with the placement....
doesnt seem like itd cause any overheating issues due to the rad being blocked. and it saves room behind the bumper for the bumper support and styrofoam for light impacts. less chance of messing up the expensive friggin' FM.
i like it. a lot. Hijacker, you able to give any more info on your old setup? coolant temps, stuff like that.
Kalypso
tramp_drift240 wrote:i kinda like that. i dont want to have to cut up my pig bumper for a FMIC.
OH! im silly
I thought you preferred side mount Intercooler'sto front mounts
but yeah I agree with you and hijacker I dont think the heat soak will be too serious.
but when dontyouhatepants is done we'll all find out.
Nissan240sx_s13
Car: 1990 Nissan 240sx
Too bad his dad crashed it thoe...
Kalypso
yeah, it could have been avoided.
beautiful car, now they need to build something better.
Hijacker
'94 F-150
tramp_drift240 wrote:ABOUT THAT GRAPH.
My old setup utilized a Saab 900 FMIC. As for coolant temps, I've only used the Nissan temp gauge in the cluster. But like I said, the only times the car has overheated, has been from bad wiring on my e-fan. Sit at idle long enough, and any radiatior without a fan pulling air across it will start to overheat. The Saab IC was massive too. It was a thin core, but it was as tall and wide as a 240 radiator, so it blocked the radiator pretty well.
The new spearco is much smaller, but thicker. It's 24"x6" and 3 or 4" deep. Where I have it tucked, it gets direct airflow from over the bumper (open grill in place of the silvia light bar is a must for this placement) and it covers up less of the radiator. Using this particular core really flattened my torque curve out, which makes me happy.
Kalypso
any pictures?
EVbot d.e.t.
Car: '91 sr coupe
Hell yes! Matt @ Import Intelligence first showed me a midmount setup like a year or two ago. Had it on an sr and that thing spooled super fast.
This is exactly the same setup I'm going to install in my coupe over the winter, probably with a slightly smaller core though. Not too worried about heat issues.
Right now I have a single 14" behind my radiator and coming back to the pit after a 20-30 drift run it's cool to the touch. I figure I'll keep that fan and sandwich a second between the I/C core and the rad for max airflow.
Modified by EVbot d.e.t. at 1:02 PM 8/4/2008
tramp_drift240
yeah, i was just wondering if the IC blocking the rad would make it any easier to overheat. i know about the idle without a fan thing, haha.
but thanks for the info! very much appreciated.
OP, cant wait for you to finish it all up so i can see the finished product.
