Underground Motorsports: Project 800HP RB26DETT 1998 240SX
Sil240
Car: Nissan S13 "The One Cam Wonder"
"I recommend this on any series RB motor, but especially the 25 and 26."
The 20 doesn't have the same problem or it is different?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I believe it is an issue with all RB's. CarlH has two 3/8" brass fittings instead of one huge -12AN fitting. I have done the same, but am waiting on my next phase to plumb it back to the 3/4" fitting from the turbo oil return.
I don't see how a -12AN fitting is going to fit between the head and the fire wall, but maybe you have looked at that already. I have about 0.25" between my brass fittings and the fire wall and that is with some pounding in of the firewall. Probably would have touched otherwise.
underground
Car: 98 RB26DET 240SX
Darius wrote:I believe it is an issue with all RB's. CarlH has two 3/8" brass fittings instead of one huge -12AN fitting. I have done the same, but am waiting on my next phase to plumb it back to the 3/4" fitting from the turbo oil return.
EDIT: I can not link to Fresh Alloy, as apparently that website is banned. But there is a Group Buy on the Head Mod pieces in the GTR Subsection, and you are welcome to read more about it there.
BoostFab
Car: S13cp, S13fb, S14z
damn that hole is bigger than my sink draining hole... lol
underground
Edit: RB25DET 5Spd transmission w/ Exedy Triple Disc Clutch will be used for the Stage 2 build.
Modified by underground at 7:31 AM 5/9/2007
underground
Yesterday, Andy at Southern Imports in Murfreesboro, TN (Mechanic on Project 240SX) installed the Mazworx Axles w/Hubs (http://www.mazworx.com) and SPL Pro Aluminum Subframe Fushings. (http://www.splparts.com)
A little brake cleaner and some black spray paint really improved the look of the spindles.
As you probably notice, the threads on the hubs are extended for use with aftermarket drag wheels.
Shocker
Car: 89 240sxHB rb26/30
what kind of 60ft's are you cutting with the megan coils and also tires that you are using?
gawdzilla
Car: none
Shocker wrote:what kind of 60ft's are you cutting with the megan coils and also tires that you are using?
his car isnt running yet?
Shocker
gawdzilla wrote:his car isnt running yet?
this I know, was talking previously.. as in last year.
ATpossible
Car: 1995 Nissan 240sx
sorry for the random question but where did you purchase your spark plug cover? the skyline gtr nissan...
i've only been able to find it at one place and it seemed way to expensive
thanks for the info
Booztd 3
Car: 1990 Nissan 300ZX TT
ATpossible wrote:sorry for the random question but where did you purchase your spark plug cover? the skyline gtr nissan...
thanks for the info
it is only the decal that sais 'R34 GTR' and you can buy them from RB Motoring. They are typically 80 Bucks
gawdzilla
Car: none
its a nissan japan part. you can get the PN in FAST. regular price is like $43 or something IIRC. definitely not 80, although that might be the case for someone stateside to have it in stock.
ATpossible
sorry, dont mean to thread jack just wanted to know how i can get this
really cuz it seems to stick up(3Dish) like the stock cover for the r32?not sure tho since i've never had one but have always wanted one
gawdzilla wrote:its a nissan japan part. you can get the PN in FAST. regular price is like $43 or something IIRC. definitely not 80, although that might be the case for someone stateside to have it in stock.
PN? as in part number? thanks for info ill try harder to find that.
Carl H
any rb motor that will see high rpm use or extended track work should add in external drains...dual or single, do something!
Shocker
Carl H wrote:any rb motor that will see high rpm use or extended track work should add in external drains...dual or single, do something!
he is a -12 an line.
underground
Just uploaded, photos of today's progress:
Desynz Motorsports Oil Return Head Mod Kit:
Polished Balance Tube:
ATI Race Engine Damper:
underground
I am using Apexi N1 Pros, however I will be switching those out for HKS Hyper Drag's this season.
If Megan made a low spring rate coilover, I'd be all over it.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
I've got a question.
If say, i track my car, i will be hitting revs no further than 6800 (ignition cut) (not fuel cut) Will if not later on should i be looking into the head drain mod? Im on the stock turbo and motor basically, i have an aftermarket intake manifold, and i plan on GT35R and possibly cams later on, if i take the head out to do a gasket and resuface, would you think its still worth it?
Shocker
Kansei240sx wrote:I've got a question.
yeah I still did it, But i'll be taking my 25 to 7700-7800 rpms. Id rather be safe than sorry. Plus its easy and cheap.
underground
I would, and I would also install two Tomei Oil Restrictors in the block when you get head pulled off.
underground
Getting Closer:
Ramius83
Car: 1995 240sx SE
Wow man, looking good.
What type of RPM/response are you looking to get full boost by with that turbo? I am still debating the 2530s or a single turbo.......hmmmmm......
underground
4500 RPM.
240sxHitman
Car: Boosted '91 240sx
The more I see these pictures, the more I wish i had money to do a Rb26dett swap.
Keep up the good work, car and motor are pretty sick
Ramius83
Car: 1995 240sx SE
Did you have to modify the Greddy exhaust manifold in order to make it fit in the chassis, or is it totally unmodified. Thanks for your help man.....
gawdzilla
Car: none
Ramius83 wrote:Did you have to modify the Greddy exhaust manifold in order to make it fit in the chassis, or is it totally unmodified. Thanks for your help man.....
pretty sure the wastegate tube needs to be cut off/modified to clear the column on LHD
FAST-DATSUN
we have to move the waste gate to clear everthing.....on the greddy manifolds
blurrbosi
Car: 240's
I Love the valve cover/s on the 26's... OMG it looks sooo smooth
underground
Yep, the wastegate piping has to be moved, and I'll know more this week, but it appears to be fairly labor intensive.
underground
Speed by Design (Setrab Model #925) Oil Cooler Kit for the 240SX
