kjlindgr wrote:
There is no possible way you spent $3,000 on your oil setup and still don't have a pump. I've got a full 4-stage dry sump setup with custom pan, reservoir, mounts, cooler, and braided steel lines all the way around and don't have $3K into it.
I don't know if you did your own fabrication... but I presume that you did, if you have a 4-stage dry sump setup with a custom oil cooler. I don't have the time, skills, or resources to do it myself. Including the cost of a oil cooler and custom fab for that (mount, shroud), accusump with epc valve, lines, fittings, labor, etc... came out to right about 3k so far.
My cooler has been setup so that it is inside the engine bay, right behind the passenger side headlight. When I don't need light (track day in particular) I remove the functioning headlight and place in a gutted headlight that serves as a ram air intake. The gutted light has molded mesh in the front to model the replaced headlight, and it looks very clean. Cold air goes in the ram headlight, through the shroud, through the cooler aided by a pull fan, and down the cold side of the motor. I haven't seen oil temps over 95 degrees C after a spirited drive... and that's in 100 degree az weather. Normal driving in that weather I never see more than 80 degrees C oil temp.
The work was done by DynoComp here in Scottsdale. It's pretty cool, no pun intended.
