Ok I just took it off. I took this time to change both the terminals with some new ones. I also added 5 more grounding straps (cant have enough) From the battery to both sides of the block, one to the intake, one to the head, one to the transmission. I have already got the normal one that goes to the chassis. there is about 0.5~0.8 ohms resistance from where the battery negative terminal is to any point on the engine.themadscientist wrote:Reset the computer. Pull the battery negative for about 10 minutes. See how it runs after that.
Good advice but I had already done this since I did the timing belt about 2 months back.new200guy wrote:another big thing is check your timing. make sure that is correct. i checked mine last week and noticed is was off by about 10 degrees and it felt really low on power. now it pulls much better. might want to pull your CAS off (after marking its current location if you dont have a timing light handy) and check the splines on the exhaust cam and the back of the CAS and make sure none of the holes are wollowed out.
hope this helps.
How can I test the ignitor. I had a feeling it could be this but because the car did run I looked past it.r34 gtr wrote:hows the ignitor? sounds like you may have a weak spark that is breaking down under any kind of load.
I stopped by my local wrecker and got a another one. Yeah it made a real difference other wise I wouldn't have said that the problems fixed. I suggest you test your ignitor first from the picture i posted up before you go and get another ignitor because its not hard for me to get one but over in the states im guessing its a real pain in the ***Masterdebater wrote:k now explain to me how u fixed the ignitor. did it reall make a difference?
Masterdebater wrote:ya im thinking i forgot to ground my ignitor....ill check it. so it helped but didnt fix ur problem?
^^^^ Yeah of cause it fixed the problem. Make sure its got a good ground.jdm s13 wrote:I fixed the problem. It was the ignitor. Thanks for your help.
clean your afm buddy even if it looks clean, spray it with some electronic contact cleaner.Masterdebater wrote:yea i did ground it and i took out my cat and cleared it out so everything is flowing right but its still messed up...the best way to describe it is its like hitting the rev limiter at 3200rpms...
