Under load my CA has no power off boost
jdm s13
Car: JDM S13 silvia
no don't scrub it. don't touch it with anything. just give it a good spray. don't use carby/throttle body cleaner because that leaves a sticky residue.
Masterdebater
Car: 1989 nissan 240sx coupe
nah no luck there....fuk...im stuck paying someone to fix it i guess.
jdm s13
Car: JDM S13 silvia
Masterdebater wrote:nah no luck there....fuk...im stuck paying someone to fix it i guess.
You have checked for vacuum leaks right?
Masterdebater
i have a small one in the back by the #4cyl so to say... back by the break booster. sprayed some break cleaner back there and it made it bog so i know teres one back there.
jdm s13
Car: JDM S13 silvia
If they are cracked/ split cut off the bad parts or replace the hole line. See if that fixes the problem.
syphrus
Car: 92 240sx coupe CA18DET
My car was having the exact same problem. I cut the ground to the MAF and added a direct ground from that to the body. Cars been doing fine now. But from my experience, those problems are vacume leaks, boost leaks, and mainly MAF. check and recheck it.
240sxbobbis
Car: owned a ca18det s13 two of them, jeep wrangler, suzuki gsxr600, 86 mazda rx7, and a y33.
another happy camper
Masterdebater
just changed my spark plugs to NGK bkr6e's and gapped them to .030 and STILL have the dam problem. ive also cleaned the maf, chenged vacuume lines around, disconnected the BOV graounded the head, grounded the ignitor, cleaned out my cat.,checked compression (160 across the board),checked vac leaks (one small one in back of motor. i have a Vortec rising rate fuel pressure regulator too but u think that would work if my stock reg. is bad?
ca18det240hatch
Does it hesitate until 3 and then hits boost and buggers off?
Masterdebater
it gets to 3000 just fine but once it gets to boosting it just makes a put put sound lmao
syphrus
Hmm.. different situation. I know you probobly have, but did you check for leaks in the IC piping. I know that will cause a problem like that. Sounds like some kind of turbo related illness since most ca's begin boosting at around 2-3. (i think, im pretty new to this and besides, my tach doesnt work) just go from easy to hard, sucks not being able to figure it out, but when you do.
Masterdebater
yea i checked the ic piping for the most part. ima take it all apart tomorrow. and change the regulator
jdm s13
Car: JDM S13 silvia
ca18det240hatch wrote:Does it hesitate until 3 and then hits boost and buggers off?
Thats what mine was doing and just under a week later its started it again!!!
Masterdebater
ima try that vortec regulator on my car. i just hope it wont lean out my engine and fry anything lol. how can u tell if the reg. is a 1:1 ratio
Masterdebater
still stumbling. buuuut... if i just do partial throttle then i can rev as high as i want. but once i throw boost in it, she bucks like a bull. maybe i need to check for boost leak....this damn engine is pissing me off.
driftin8ez
Car: 92 Coupe, Turbo Miata
im kinda jumping in this late... But, Whenever i think i may have a leak in my ic piping i try and drive the car with the maf unplugged. If it idles better and seems to drive better up to 2500 rpm then i really try and hunt down the leak. Other wise it could be something slightly more serious.
float_6969
OK, I'm confused now, I thought the car ran fine on boost, but stumbled off boost. But now it sounds like you're saying it's fine below 3K (off boost) but stumbles on boost.
Probable Solutions:Stumbles off boost: Leak in piping, intake manifold, brake booster line, etc. Maybe bad MAFS.
Stumbles on boost: Bad ignitor, coils, or plugs. Maybe bad MAFS, but unlikely.
Masterdebater
as long as i dont put any load onto it to boost i can rev as high as i want but once i punch it to boost then it just stumbles. in other words it wont boost at all
jdm s13
Car: JDM S13 silvia
Masterdebater wrote:as long as i dont put any load onto it to boost i can rev as high as i want but once i punch it to boost then it just stumbles. in other words it wont boost at all
made any progress? i sure haven't.
Masterdebater
im toolazy right now. goin through some shyt so yea....maybe im losing air through an injector o-ring on cyl #4...ill find it tho. but its weird how just a lil bit ago my car ran fine and now its allweird...maybe its this home fabricated boost controller.
Masterdebater
yea it was the shyty boost controller i made. now i have it retuned and now she runs like a champ again!!! now i dont want to have to sell it ((
jdm s13
Car: JDM S13 silvia
LOL! at least your problems fixed now mate.
Masterdebater
yessir just check around for a vacuum problem...its not a boost leak its most likely vac...
jdm s13
Car: JDM S13 silvia
Found mine. I cleaned out my PCV and BAM leaking from there!
Masterdebater
woo!!!! well done sir i believe this thread is done now.
