msaskin wrote:It shouldn't take that long. I can drop an SR transmission in about an hour now, probably faster if I didn't take my sweet-*** time while working on cars, what, with friends and beer usually around
~matt
DukeBoy wrote:I'm not talking about dropping just the transmission. I am talking about disconnecting the wiring harness, vacuum lines, radiator, intercooler and pulling out the motor and trans together; pulling the trans off the motor, take the clutch off and retorque the bolts, put the clutch back on and reconnect the trans in 3 hours. the blacktop sits too far back on the firewall to drop the transmission while its in the car. i think this was far easier.
msaskin wrote:ohhhh...gotcha. I wasn't aware the blacktop sat any further back than a redtop does.
~matt
~matt
what do u mean "6 one way, hald a dozen the other" anyway half a dozen is 6tenkawa_akito wrote:it doesn't. you can work on the fywheel with the block still in the car, but it is a bit easier to work on the flywheel with the motor out of the car. Especially if you don't have a lift to work with. I look at it this way: 6 one way, half a dozen the other.
