drifter_for_life06 wrote:if you get a twin turbo, no doubt you are going to have MAJOR turbo lag and you will spool up rediculously slow. So to fix that my solution would be as follows: You have two turbos, one is smaller than the other(for example a T25/T28 bad example but you get the idea) with this setup the smaller turbo will spool quicker giving more power at lower rpm's eliminating the LARGE turbo lag, and as this turbo begins to reach its maximum output of power, the secondary or the larger turbo, is spooling up, putting out its maximum power. So (i thought) in theory you would still get loads of power, AND eliminate the lag. Now indeed you would have to maybe fabricate a few things and get the exact turbos to spool right, so that not all your power is mid range RPMS
So that is my theory, what do ya think? Yes/No/Maybe
welcome to 20 years ago
. Thats been done and has been in a few cars in the 90s. Bro, unless your going for novelty (and have the knowledge and cash to back it up!) the TT setup just isnt practical. Your sequential idea makes sense but is not applicable. Two T25s would spool up just fine on a 2L engine. There wouldnt be "major" lag. The only time I would consider 2 turbos is with a V block, not an i4 or i6.
Also you should consider that one properly sized turbo is always more efficient than two smaller turbos. Im refering to specifically to the compressor housing clearance between it and the blades, and the number of pulses. Even if you can get T25s for $50 its not worth it.
