Twin Turbo VH45
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
DRFTBLD
Car: 89 S13 VH45DETT
05 Ford F-150 Drift Support
91 S13 Tester
08 Ford Focus
Does anyone have any info on a twin Turbo VH45 Set up in an S13/14?
Pic threats would be great too :crazy:
gs14racer
one guy does and another is building one,
I have a supercharger and jeff taylor has a monster single turbo.
DRFTBLD
91 S13 Tester
08 Ford Focus
SuperCharger... Nice :dblthumb:
DRFTBLD
91 S13 Tester
08 Ford Focus
gs14racer wrote:one guy does and another is building one,
Do you happen to know who it is that does have one?
Chrispy300
Car: 1993 J-Spec 300ZX 5 Speed Slicktop
One guy here, I think his nick is Canadian Drifter. Build thread was something like S13 VH45DETT. Had lots of pics and a couple of vids. Pretty hardcore.
DRFTBLD
91 S13 Tester
08 Ford Focus
totalp
Car: C35 Laurel
Does anyone know if there is a stroker kit available for the vh45/vk45 and who makes low compression turbo pistons for them? Thanks
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
no and no one yet
Chrispy300
totalp wrote:Does anyone know if there is a stroker kit available for the vh45/vk45 and who makes low compression turbo pistons for them? Thanks
You can get the crank offset ground, I'm sure Paeco can do it for you.
CP make custom pistons for whatever you want. Low comp forged VH45 pistons are available from them, often a few listings on ebay.
st10034
Car: Black 1995 240SX
Im working on getting this one going. It will be going in my S14. Hopping to find another car so i can park my S14 and beging fabrication. Oh and a second job wouldn't hurt LOL.
Some of you guys might recognize this motor. It was the one that Tecni was building. It has Venolia pistons and Pauter rods, with 9:1 compression.
David Steele
Car: S13 FastBacK
I would disassemble that engine and reassemble it if I were you, he offered me that engine, but I turned that down the Pauter rods in it .
The specifications of those rods they are the same specification to go in VK45's at least thats what they said.
Rod length : 147mm
Wrist pins 8.66
BE:8.65
SE: 22mm
Price :$1576
IMO those rods are much too heavy.
st10034
Yep that was my plan. I don't like relying on other people's work. I rather spec everything out and replace all gaskets myself, and make sure everything was torqued correcly.
David Steele
Car: S13 FastBacK
st10034 wrote:Yep that was my plan. I don't like relying on other people's work. I rather spec everything out and replace all gaskets myself, and make sure everything was torqued correcly.
Use a rod bolt stretch gauge on those rod bolts, call up pauter to find out what hardware they are, and what to stretch them to do not ''torque'' those.
Just some friendly advice.
st10034
also what do you mean
Wrist pins 8.66
BE:8.65
did you misplace the decimal? are you using in or mm? im pretty sure you don't mean inches cause that wouldn't fit in the engine, and that would be way to small if it's mm.
Probably just a misstype.
David Steele
Car: S13 FastBacK
st10034 wrote:also what do you mean
Wrist pins 8.66
BE:8.65
BE width and wrist pin diameter in inches I placed the decimals wrong.
Then again I took these down to make something since I discovered the VK56 crankshaft fits in the block the crank snout just needs to be modified, and I managed to find them being sold cheap. I can get you full specifications just can't find my complete notes.
st10034
Yeah, I doubble dchecked the measurements for the VK and the VH on the FSM and all the dimentions are the same. Only diference is that the VK gives you less of a difference in the big end diameter VH is 55"-55.019" and the VK is 55"-55.013" so that means the rods are interchangable.
I don't doubt he got the right parts for the build, but I just don't trust other peoples work when it comes to something with tight tolerances. I can be more at ease that the engine is built right if I do it myself, and not have to worry about it destrying itself before I even get to tune it.
Thanks for the help though im glad to see that people in this forum acctually look aout for oneanother.
DRFTBLD, sorry didnt mean to take over your thread.
DRFTBLD
91 S13 Tester
08 Ford Focus
No prob.... just still reading all the info. Can't wait to see you car? Do you have a built thread?
st10034
No build thread yet, it probably won't be done for a while, so I rather not make a build thread until I have all the $$$ or all the parts. I can't wait to finish, might pick up a second job just for the build. Unless one of you guys want to fund my build . lol
David Steele
Car: S13 FastBacK
st10034 wrote:Yeah, I doubble dchecked the measurements for the VK and the VH on the FSM and all the dimentions are the same. Only diference is that the VK gives you less of a difference in the big end diameter VH is 55"-55.019" and the VK is 55"-55.013" so that means the rods are interchangable.
Vk56DE have larger connecting rod journals, so these specifications are only valid for the Vk45DE.
That small variance could be the difference in room temperature.
st10034
yeah, i forget about the VK56. But i was looking at the VK45 for the specs.
DRFTBLD
91 S13 Tester
08 Ford Focus
I can't wait to see more on this build!!! it's gonna be a killer to see!!!
Sender
Car: S15 FGY32 VH41DE
Japspeed S15 drift car
build thread
http://www.driftworks.com/forum/drift-c ... o-s15.html
hannibal
Car: Red Line to Glenmont
^ Thats nice!
DRFTBLD
91 S13 Tester
08 Ford Focus
hannibal wrote:^ Thats nice!
I second that!!!!
Chrispy300
Lol! Screamers out the bonnet! :D
Return to “VH45DE / VK45DE / VK56DE Forum”
