canadiandrifter240sx »
https://forums.nicoclub.com/canadiandrifter240sx-u38452.html
Fri Apr 06, 2007 9:57 pm
It has been a while since the last update so I fugured i should post some pics and get you guys up to speed.
Things have been going slow and it does not look like alot has changed but that is because most of the work I have done recently is all the small stuff mainly to do with the intakes (IAC, PVC, Coolant lines etc...). All that stuff has been more difficult then I ever imagined it would be. I am trying to keep a clean cimetrical look and i makes things difficult....I don't want to just throw a bunch of hoses all over the place.
I have welded the stock IAC (cut off of the Q intake) to the back of the right bank intake runner and have used a Y hose to go to each runner and I have used 2 bolt on bungs taken from PS pumps the feed into the runners.
Then I took the PVC "T" found behind the coolant filler on a stock VH and welded it to the back of the thermistat houseing under the intakes.
I also moved a coolant temp sensor from the top of the coolant "Y" in the valley to the back side (this will be the one I use for the ECU and the one at the front will be removed). Does anyone know why there are 2of the same sensors? Is there only 2 on the TCS models?
I have also removed the coolant filler and rad cap then welded the hole shut and clocked it to come out under the throttle body.
Now I am going to finish the IC pipeing and start on the clean up. I still need to get 2 waste gates, 2 BOV's (HKS SSQV's) the rad and a clutch. Then I need to get the body blasted and painted.I could have the car done by the end of the month if I had all the funds but my budget is gone so it will take some more time unless I find a sposor to help out.......anyone know of any sponsors?...lol
Ok I will shut up now and post the pic's
Modified by canadiandrifter240sx at 10:00 AM 4/7/2007
