Sorry for the slow respons, I have been working out of town.Hogg wrote:
CanadianDrifter - what kind of sensors and vacuums are left on your motor and what ECM are you using for this setup as I see no MAFs?
X2maxnix wrote:This needs an update!
Hey guys, sorry about the lack of posts, not too much has happened with the car. Difting is expensive and I have no sponsors so building a drift car while maintaining a drift car is hard to do.ghettoslide wrote:That is really great work, where did you find the intake setup, or is fabed by you i like it. I am planning this swap for my s13, where did you find internals or are they all stock. If so what boost level are you up to. This looks so much cleaner than the stock intake setup and sits much lower i would imagine. Truly good work man.
If you read the thread you would see he is doing the work himselfa_ahmed wrote:
By the way I want to do the same thing to my chassis, where are you getting this work done and how much? Got an email we can speak through?
Actually, turbos have everything to do with it, as they are ALWAYS boosting to some degree. Push more power through an engine, and of course it is going to rev quicker. It won't drop revs as quick if you don't lighten the rotating mass, but it'll rev to the moon in a heartbeat if you let it.Aus450zx wrote:If you read the thread you would see he is doing the work himself
In the vid showing the car revving I think the tacho has been calibrated wrong, the engine shouldn't rev that fast without some serious changes to the rotating mass and probably some ITB's should it? Obviously turbo's have nothing to do with it as they wouldn't be making boost revving in neutral. Was the tacho set up for a V8?
actually no, boost is positive pressure above atmospheric, with large turbo's it is possible and likely for them not to create boost revving out of gear as there is no load to help them spool.PanzerAce wrote:
